Go Back   SR20 Forum > Classifieds > Group Buys
Closed Thread
Old 03-15-2003, 12:05 AM   #141 (permalink)
Got mine as well. Had to take the car for a quick spin tonight to test it out. Thanks Greg.
-Mike
mpg9999 is offline
Old 03-15-2003, 09:37 AM   #142 (permalink)
I e-mailed Technosquare about the CMX manuals, which are written in Japanese.
They said they would e-mail me the English version when it is translated.
jp314 is offline
Old 03-15-2003, 12:39 PM   #143 (permalink)
FWD PWNAGE IS HERE!
So they are different?
Originally posted by jp314
It displays the timing at the ECU, not the base timing. [/b]
'93 240SX - Stock for now
'95 G20 - The DD - 210K and counting
'96 G20 - Beating up the streets of SL,UT.. watch out - 334WHP/313TQ
www.UtahNissans.com
www.RallySportDirect.com
SR20 Inside is offline
Old 03-15-2003, 09:57 PM   #144 (permalink)
Road Race DE
Todd98SE's Avatar
MDM-100
Mine arrived yesterday. Unfortunately it doesn't seem to work with the stock 98' ECU, all i get is "communications error 02". I guess I'll have to wait until I swap in the 97' JWT Turbo ECU.
Thanks Greg for setting this up. Much appreciated.
Todd Friar
98' Sentra SE
Todd98SE is offline
Old 03-16-2003, 12:55 AM   #145 (permalink)
So you have to add like 6 degrees from what the unit says in order to know what your timing is?
Not installed -yet f-max stg ll with all the additional option, waterinjection,72lb injectors,ballbearing turbo,JWT cam sprockets,300zx fuelpump,cobra maf, installed -TSURU front headlight/grill conversion,Ground Control coilovers, tokico blues in the front, kyb AGx in the rear, strut tower bar, short throw shifter, TSW VX-1placeracing coldair intake,intakemanifold polished,head ported and polished with intakevalve bored 1mm,Hotshot headers,2.25 mandrel bend exhaust, Turbo exhaust, Magnecor wires, ACT clutch,zex lightweight flywheel,MSD Digital+6,Blaster SS coil,80 shot directport,UR Ultra SS pulleys,Brembo slotted rotors, KVR brake pads,
Best 1/4 13.99 in Hi.
Quick92Se-r is offline
Old 03-17-2003, 08:55 AM   #146 (permalink)
The ECU is constantly adjusting the timing - advancing / retarding from the base timing setting.
You set the base timing, then the ECU adjusts for different conditions.
I watched mine on the MDM-100 for awhile yesterday. It displayed anywhere from 5 to 34 degrees.
jp314 is offline
Old 03-17-2003, 08:30 PM   #147 (permalink)
I am a quiter
I want my mdm-100 but I won't be able to check my mail for about 4 months. This sux stupid wars
Why put off till tomarrow what you can finish today?
njdan69 is offline
Old 03-20-2003, 02:09 PM   #148 (permalink)
Veritas
SERprise In WV's Avatar
Trader Rating: 17 (100%)
Josh--
The CMX instructions are *very* simple, as it only has 2 buttons as you know.
Right button: Switches from TeMP-SPeeD-INJ-AFr(MAF). Temp is in *F, Speed is in MPH, INJector duty cycle is in %, and AFr (MAF) voltage is in, duh, volts.
Left button: Peak recall of the currently-displayed parameter. You can *only* do peak recall of one function at a time, the one that is being displayed.
Set the CMX to INJ, for example. Make a dragstrip run. After the run is over (before the ignition is turned off) and press the left-most button. Voila', it will tell you the highest INJector % attained during the run.
Same for the other parameters.
Just a tip: Using peak recall on the SPeeD parameter is kick-ass at an autocross for seeing if you went faster or not.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: www.TurboChargedSE-R.com
Great parts at great prices: PowerTechPerformance.com
SERprise In WV is offline
Old 03-20-2003, 02:38 PM   #149 (permalink)
I'm sure I can figure the CMX out, it's just nice to have the manual, in English.
I've only played with the MDM so far. Peak recall for 2 live parameters is nice!
I know my O2 sensor is good, watching it switch back and forth, rich/lean.
The MAF voltage relates to the intake air temperature, right? If so, does anyone have a chart listing the temperatures that correspond to the MAF voltage readings?
jp314 is offline
Old 03-20-2003, 11:49 PM   #150 (permalink)
Voltage relates to the amount of air flowing through the sensor. I've noticed that the voltage changes just like a vacumm gauge would. For example at idle I my MAF is at 1.60-1.65V. If I was going say 2500rpm in 5th gear at 1/4 throttle or 0.84V TPS it would read ~2.4V. Say I go from 1/4 to 3/4 throttle, the maf would go from 2.4V to 3.4V. Just like how a vacuum gauge would read ~15inhg @ 1/4 throttle to ~7-9inhg @ 3/4 throttle. I peaked at 4.58V during a 2-3rd gear WOT run.
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
Nismo87SE is offline
Old 03-21-2003, 09:45 AM   #151 (permalink)
No, its not the temperature. It measures the amount of air, BUT, if the air is colder, there is more (its denser), therefor resulting in a higher voltage. Also, about your comparison to a vacuum. The reason for this is that the MAF voltage is a non linear representation of airflow.
mpg9999 is offline
Old 03-25-2003, 09:34 AM   #152 (permalink)
The Sky's The Limit !
Thanks Greg, i got my MDM (+alarm) this morning, all the way over in the UK. After initially having doubts as to whether it would fit on my consult port, i can now confirm that it does indeed fit and function correctly. I am now a very happy man, especially as my local nissan dealer also gave me the Nissan FAST program on my laptop today aswell.
P11GT is offline
Old 04-07-2003, 06:00 PM   #153 (permalink)
Hey guys, Have any of you tried using an mdm-100n on any other pre obd-2 nissans? I'm very interested in buying one, but i'd like to make sure it would work first. Yes, i'm going to contact techtom now also, i just wanted to see if anyone had already tried it.
thanks
U12 2NR is offline
Old 04-07-2003, 08:59 PM   #154 (permalink)
SE-R Protection League
I have tried it on a Z32 300ZX-TT and it works just fine, but when I pluged it on a Nissan Quest, it kept saying ERROR.
Guess MDM-100s don't like vans.
Enjoying the Ride since 1993
Two Classic SE-Rs, Twice the money-pit
JCCT is offline
Old 04-07-2003, 09:00 PM   #155 (permalink)
What is a Nissan FAST program??
JCCT is offline
Old 03-12-2004, 07:27 PM   #156 (permalink)
Re: Announcing the second forum group buy on Techtom MDM/CMX monitors!
sorry to dig up an old thread, but is anyone who was in this group buy, willing to trade their MDM100 for a Multichecker??
P11GT is offline
Old 03-30-2004, 12:57 AM   #157 (permalink)
they will not work on 98 and up
SEXY SUPERVISION COMPANY!!!
3BiP is offline
Closed Thread
