Blair
93 P10
Does the extra bracket for the low-port not come with the kit? If not, where can I get the bracket and how much $?
Oh, BTW, count me in too.
'98 SE-R, Homemade CAI, OBX Headers, RaceConcepts Direct-pass CAT, Tunabe Bomb-X muffler. Coil-Overs w/AGX cores, ME Mounts, Homemade STBs Front & Rear. Velox VX-6Rs wrapped in 225/45WR17s.........15.889@96mph
Much thanks to Doug & Dougie over at TigerAuto Dayton, OH for the help.
Wanted: 1)70mm TB w/flange 2)lightweight flywheel 3)96 G20 ECU 4)B13 SE-R Cams 5)FWD O2 housing & DP for a T3
I only have 3 brackets to adapt to the b14! $165 is for these 3 only! I may have to get them from Mossy Nissan (retail for about $30). So get yours quick!
High port kits are ready. $148 shipped.
gruven99 I have your kit ready to ship.
-joel
RTR
Originally Posted by gruven99
B14 kits are ready!!!!
Ordered mine today.
$165 shipped with the extra brackets needed for the lowport motor.
Joel W.
Random Thoughts Racing
http://groups.yahoo.com/group/randomthoughtsracing/
The bracket does come with the kit it is a stock bracket from a highport. I was able to get 3 used but nice ones and am charging $17 extra for these kits.
-joel
RTR
I have one B15 kit available for an adventurous person!
I did the install on busytac's b15 about a month ago and everything seems to be working fine. There was a vacuum switch that we left hooked up but were not sure what it does exactly (someone with a b15 FSM please look it up and enlighten us). The car already had a mil light so I cant guarantee the switch wont throw a code of some kind.
This kit took me about 5 hours to install and also needed a shorter belt than stock. I was able to use an existing section of the PS system to loop back into the rack so this is a reversible procedure. It went together very nicely and unclutters the engine bay nicely.
I will let Busytac post his thoughts.
This kit requires both brackets (retail at Nissan for about $30 and $55 each) from a highport pump the price is $165 shipped for this ONE kit only.
I believe that a ga can simply have the PS removed and eliminate a belt. The only reason the sr20 needs this is to tension the water pump belt. Check your belt configuration.
-joel
RTR
Originally Posted by dreadsword
hey random - can you make a GA16 eliminator? I'd like to combine this with a short ratio rack (2.25 turns) and create the ultimate auto-x steering.
