Go Back   SR20 Forum > Classifieds > Group Buys
Closed Thread
Old 04-23-2003, 01:56 PM   #1 (permalink)
Trader Rating: 16 (100%)
Pillowball mounts for stock type springs anyone?
How many people would be interested in such a thing? I've been doing the research and design and wanted to get a feel for if it'd be worth my time.
Essentially I'm thinking welding in a bearing retainer into the stock upper mount after removing the rubber/washer biscuit. I'd have to charge a core charge with return to make it work though, unless you'd be willing to pay extra.
This would be the solution for you Eibach or Hyperco guys that want the mounts but to this point couldn't get 'em.
Let me know and I'll decide if it's going to work or not.
Don't have a target price currently as I still haven't nailed down the details yet,
-SHig
SHigSpeed is offline
Old 04-23-2003, 01:58 PM   #2 (permalink)
I'd be interested. Like you said, this would be perfect for us hyperco guys.
mpg9999 is offline
Old 04-23-2003, 02:48 PM   #3 (permalink)
Evo is gone :(
Would it eliminate the noise from my rear suspension? I would pay anything to make it quiet, well maybe not anything. Just to let you know I run Hyperco and KYB's.
Evo is gone and back to a SE-R
WWW.UTAHNISSANS.COM
bullfrg is offline
Old 04-23-2003, 06:06 PM   #4 (permalink)
Original Owner
aztecred92's Avatar
I'm interested!
aztecred92
L I V E S T R O N G
'92 SE-R
'85 MR2
aztecred92 is offline
Old 04-23-2003, 07:56 PM   #5 (permalink)
Veritas
SERprise In WV's Avatar
Trader Rating: 17 (100%)
Bring it, Scott.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: www.TurboChargedSE-R.com
Great parts at great prices: PowerTechPerformance.com
SERprise In WV is offline
Old 04-23-2003, 08:23 PM   #6 (permalink)
The Groove Master
Rittmeister's Avatar
Are we talking rears only, or fronts too? I'd definitely be interested either way.
1990 240SR - the DET has landed.
Kent's Funkay Disco
Rittmeister is offline
Old 04-23-2003, 09:54 PM   #7 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
I would probably be interested. The timing would be an issue for me, unless you would offer them continuosly; and not just this one time.
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Fosters is offline
Old 04-23-2003, 10:32 PM   #8 (permalink)
merely a flesh wound
chriscar's Avatar
Trader Rating: 98 (100%)
Oh HAPPY DAY!!!!!
Hell YEAH!!!!!
Bring it ONNNNN!!!
Scott, this is a fantastic idea. I'll be the first on line for these. I was just bemoaning the fact that all of my GC owning friends who are buying your pillowball mounts were cool, and us Hyperco guys were left out in the cold.
If you build them, I will come.
Chris
chriscar is offline
Old 04-23-2003, 11:31 PM   #9 (permalink)
Veritas
TMI...
-GP-
Old 04-24-2003, 09:17 AM   #10 (permalink)
Originally posted by SERprise In WV
TMI...
-GP-
agreed.
Scott, I'm in as well.
david is offline
Old 04-24-2003, 01:07 PM   #11 (permalink)
I'm interested - NX driver! Price is my main concern....
dreadsword is offline
Old 04-24-2003, 01:27 PM   #12 (permalink)
chriscar's Avatar
Re: Pillowball mounts for stock type springs anyone?
-SHig
There are two parts to the mount. The upper part (Seat Assy-rear), which has the "hat" that you can see in from inside the car, and the lower part (Insulator Assy) which holds the spring onto the strut. Here are the part numbers and list prices.
55264-50Y10 Seat Assy-rear $19.98
55320-50Y12 Insulator Assy $38.17
I assume that your proposing to construct a new Seat Assy, retaining the stock insulator, and will need to use the guts of a stock Seat Assy. If that's the case, and you need a set of donor seat assy's, I'll be willing to buy new ones and have them sent to you.
Chris
chriscar is offline
Old 04-24-2003, 02:56 PM   #13 (permalink)
Re: Re: Pillowball mounts for stock type springs anyone?
Chris
Seems strange that the parts are named that way. The Seat does not include the spring seat, and the insulator has no rubber? I'm thinking that you MAY have reversed the terms and it'd make sense that the washer and rubber part that you see in the car would be less expensive than the part with the upper seat.
At any rate, you're correct in what you're thinking. I've got a pair of stock upper parts that I've already burned out the rubber from and I've also got a pair of NAPA parts on hold as we speak to check out.
Hopefully the aftermarket ones are close enough to OEM that I can either make them using stock cores or cheap and easily accesible ones from the corner shop.
Either way, I'm forging ahead with the plan.
-Scott
Old 04-24-2003, 03:27 PM   #14 (permalink)
chriscar's Avatar
You're right, I flipped the part numbers.
Chris
chriscar is offline
Old 04-24-2003, 09:55 PM   #15 (permalink)
egg
id be interested. you doing this for both the front and rear?
lots of turbo stuff for sale
- turbo
- manifold
- wastegate
- BOV
- JWT ECU
- injectors
http://www.sr20forum.com/showthread.php?p=494342
egg is offline
Old 04-24-2003, 11:09 PM   #16 (permalink)
Just the rears at first. Fronts may follow later. Hang tight...
-Scott
Old 04-25-2003, 03:46 AM   #17 (permalink)
I'm Coming For You
I am interested also....def.
In Search Of
SeenSense is offline
Old 04-25-2003, 08:53 AM   #18 (permalink)
Professor Dingbat
sorry, im not familiar with pillow ball mounts, what's the deal with them?
FastNX is offline
Old 04-26-2003, 04:27 PM   #19 (permalink)
These mounts will replace your current "washer in a hunk of rubber" upper strut mounts with a spherical bearing mount. What that does is eliminates all slop up and down as well as side to side in the upper mounting point of the struts.
That in turn allows all suspension travel to immediately actuate the dampers instead of allowing 1/4"-1/2" of undamped travel due to the rubber deflection. It'll increase handling crispness and reduce alignment changes during hard cornering.
-Scott
Old 04-28-2003, 12:46 PM   #20 (permalink)
Babies are a lot of work!
Trader Rating: 23 (100%)
Hi Scott,
I'd be in for a set of these pillowball mounts. I bought a set of Hyperco's from Chris and am waiting to purchase some shocks, so this would be an excellent addition for me.
Count me in.
Thanks,
Jason
JKho is offline
Closed Thread
