Go Back   SR20 Forum > Classifieds > Group Buys
Closed Thread
Old 05-16-2003, 01:06 AM   #41 (permalink)
easy 400WHP
Trader Rating: 27 (100%)
Im down for the 1-5 synchro set in G20 ratio...
I will have them cryoed on my own unless PAR will do it for a low price.. other than that.. Keep me posted.. Thanks!! This deal may be a great one!!!
**EDIT: also some kind of Upgraded LSD deal would complement this very well I believe!!!
~jRod
Originally Posted by Random Genius
"...Everyone in California is easy to deal with, in the mid-west people are so uptight and their first reaction is to get pissy to try and get results. Makes me want to move to California!..."
NX$paniard is offline
Old 05-16-2003, 03:39 AM   #42 (permalink)
SE-R Turbo Slut
Trader Rating: 29 (100%)
Originally posted by blackb13
The synchro set will be 1-4 straight cut gears. Then 5th will be helical to bring the noise level down. All gears can be custom ratio, but leave 1st and 4th the same. They will be brand new synchros as far as I know.
For clarification :
So being that all gears can be custom we will have say in our ratios?
Larry Low
LAMO IMPORTS
k6 GSXR 750
01 Ducati 996
1999 sentra se-l
1992 Pulsar Gti-r
Low612 is offline
Old 05-16-2003, 09:36 AM   #43 (permalink)
WASHED UP
Ok Question.Why cryo gears that can hold 450 hp?? are you making that much HP..?? or is it for safty?
kesi24 is offline
Old 05-16-2003, 12:38 PM   #44 (permalink)
Corporate Bullsh*t
OK...HERE IT IS
Ok guys here are the final prices and specs.
All shipping will be determined from Florida.
$2,000 plus shipping to your door on the synchro box.
$2,200 for the dog gears plus shipping. (save $150!!!)
Here is what each set includes
DOG GEAR SET:
Main shaft
Pinion shaft
Crown wheel
1st gear
2nd gear
3rd gear
4th gear
5th gear
5th pinion
1&2 Hub
1&2 Slider
3&4 Hub
3&4 Slider
5th Hub
5th Slider
SYNCHRO GEAR SET: IN G20 RATIOS
Main shaft
Pinion shaft
Crown wheel
1st gear
2nd gear
3rd gear
4th gear
5th gear
5th pinion
New synchros can be ordered, but I'll have to get a price on them. The NISMO LSD will be priced soon also.
Cryo will need to be done on your own since PAR suggested against it and I am going to side with the manufacturer on this.
All orders need to be sent to pargearset@hotmail.com so they can be contacted with regards to payments on other parts related to the transmissions they may want.
When emailing, please include: Full name, contact #, and what you want ordered. Please be very specific when ordering. (make, model, year, ratios requested, synchro, dog, etc...)
For questions, please post on the forum! The email is for payment and orders only!
The custom ratios will be delt with at a one on one approach with the customer so that everything can be clear and the order correct. The custom ratios will most likely take longer then the G20's because of the custom application and processing.
I've already made my order!!! Who's next?
92 SE-R, turbo
blackb13 is offline
Old 05-16-2003, 01:16 PM   #45 (permalink)
SE-R Turbo Slut
Re: OK...HERE IT IS
DOG GEAR SET:
Main shaft
Pinion shaft
Crown wheel
1st gear
2nd gear
3rd gear
4th gear
5th gear
5th pinion
1&2 Hub
1&2 Slider
3&4 Hub
3&4 Slider
5th Hub
5th Slider
Main shaft
Pinion shaft
Crown wheel
1st gear
2nd gear
3rd gear
4th gear
5th gear
5th pinion
Well i guess im next!
Low612 is offline
Old 05-16-2003, 02:52 PM   #46 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
Are we still doing the split payment thing? I guess I will email them.
Brent
coach is offline
Old 05-16-2003, 06:09 PM   #47 (permalink)
easy 400WHP
what do you guys recommend be done about synchros...?
new ones? or use the ones we already have?, etc...
what would be best and any price quotes would be handy as well..so I can budget this entire venture...(including the LSD deal)
Thanks in advance!!
Old 05-16-2003, 06:11 PM   #48 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
i'd like to know about a synchro gearset with new synchros and a new LSD
KL0 P11 Sport
Surround Sound
My VE thread
civicdragon is offline
Old 05-16-2003, 09:16 PM   #49 (permalink)
easy 400WHP
yeah that sounds good...the complete package!!
Old 05-16-2003, 09:16 PM   #50 (permalink)
if you get the dog box set do you still use your factory synchros or do you not install them b/c of the dog gears???
11.55@124.24 mph
FULL INTERIOR
367HP 340FT-LBS @18PSI
My Webpage
insaneser is offline
Old 05-16-2003, 10:13 PM   #51 (permalink)
CSERT MEMBER
no synchros are used in dog gears
Give me your tears gypsy or I will take them from you
Carlos
74 Datsun B210
93 Black SE-R
99 G20
93BlackBird is offline
Old 05-17-2003, 12:06 AM   #52 (permalink)
Power to spare...
Ok someone explain the advantages of the TALLER G20 gearset?
Taller means weaker more stress on gear=easier to break.
Taller means better gas mileage=I get 30-34mpg now which is more than enough for me, so that's not a concern for me.
Turbo lag on T3/TO4E's are bad enough as it is in my opinion and taller gears would further increase the lag. Now I know you guys with T25's and T28's have mad wheelspin down low so maybe that's whose suggesting taller gears. Also Mike explained that the G20 ratios were hardly different and the closer to stock the stronger...
Would it be just the gear ratios that are going to be G20's or the final drive as well?
Why didn't we get to all vote on this to see what the majority wanted?
'97 200SX SE-R GT28RS Powered
'06 Mitsubishi Lancer Evolution IX
Thomas Reynolds is offline
Old 05-17-2003, 01:54 AM   #53 (permalink)
CSERT MEMBER
ok guys it really doesn't matter if you want the g20 or the stock. when you send your order in just specify stock ratios or g20 ratios
Old 05-17-2003, 04:26 AM   #54 (permalink)
SE-R Turbo Slut
yes ditto
Low612 is offline
Old 05-17-2003, 04:39 AM   #55 (permalink)
Other Prices
blackb13,
Before I place my order, I am waiting on the other prices for the New synchros and NISMO LSD so I can have a final dollar amount if I want the other items. I am going turbo next year but I am gathering up the parts I need to go turbo. If there is a good deal for the NISMO LSD, I am in. I would prefer to get the total package so I can say that I have the parts to upgrade the tranny and diff.
Current Mods Completed: Brakes, Suspension, Shifter, Front and Rear Lights, Rims and Tires
(Not in any Order) Future Mods: Differental, Transmission, Fuel System, Turbo, New Paint (Super Black), Interior, Stereo System
SE-R Newbie is offline
Old 05-17-2003, 11:22 AM   #56 (permalink)
Power to spare...
This sucks because how do we know what the actual case will be.
For example it could end up:
3 - G20 Ratio sets
7-9 Stock CUSTOM sets
Then MOST people will wait longer since it's a CUSTOM set as it is not the G20 set.
Hence my question I will ask yet again: Why did we not get to vote?
Old 05-17-2003, 01:55 PM   #57 (permalink)
SE-R Turbo Slut
It would only make sense that the easier sets be done first. Just because theres custom ratios dosent mean there going to be ordered.But who knows.? Iam getting the regular g20 set. IMHO rather than being concerned about why we did not get to vote. The question is will the orders be shipped together at same time or seperatley.
If a custom ratio is ordered will that delay others orders any length of time
Low612 is offline
Old 05-17-2003, 07:19 PM   #58 (permalink)
CSERT MEMBER
I didn't write that blackb13 wrote that. He added that, but I corrected him in a private message. I was going to let him post it because he had started the thread and I didn't want it to seem like I was hijacking it.
So to clear everything up. Pick what you want and all the gearsets will come in at one time. If you e-mail with the ratios you want we can discuss it by e-mail or on the phone. In the email say if you want Dog or synchro and if you want stock or g20. If you want some other ratio we will discuss that one on one by phone. All orders will be shipped at the same time.
ALSO:
I am working on LSD stuff for you guys. I assume you want nismo. I will be talking to my Nissan dealer about hooking us up. Nismo does not give quantitve pricing for the products. Its a flat price. Please e-mail pargearset@hotmail.com if you would be interested so I can tell the dealer what quantity we are looking at. Synchros will also be priced monday.
IF YOU ORDER A DOGSET PLEASE UNDERSTAND THAT YOU WILL BE DOUBLE CLUTCHING FOR THE REST OF YOUR LIFE. PAR AND I WANT YOU TO KNOW THAT EVEN THOUGH MIKE SAID THEY WERE STREETABLE THEY MAY NOT BE FOR YOU. PLEASE KEEP THIS IN MIND WHEN YOU MAKE YOUR ORDER.
I hope this clears up some stuff and I will be personaly replying to all questions. you may also now send questons/concerns to PARGEARSET@HOTMAIL.COM
Thank you
Carlos
Old 05-17-2003, 07:54 PM   #59 (permalink)
N.A.S.A instructor/racer
i need to order the g-20 synchro set,do i order through PAR only or do we have u.s. dealer?
http://www.xxtuning.com/xxpics/jackani.gif
1991 SE-R 1.6/2.0 track #151 2000 subaru rs 3.3H-6 track #33
madddjack is offline
Old 05-18-2003, 02:53 AM   #60 (permalink)
CSERT MEMBER
me I am the US dealer. You can order everything thru me. I am the one getting the g20 ratios made
Closed Thread
