First I am the one running this groupbuy. I didn't want it to seem like I hijacked the thread from blackb13. I must agree that with our names being similar it was confusing, for this I apologize. I set up the details with par and I am the one in Direct communication with PAR. This groupbuy is for Synchro and Dog gearsets only. LSD groupbuy will be done afterward. Any internals other than the gears and the LSD can be asked about via e-mail(ex: bulk rings, seals, etc.). The dog gearset will only be offered in stock SE-R ratios at this time. All 5 gears will be offered for the dogset. The synchro set will be offered in stock SE-R ratios or G20 ratios. All 5 gears will be offered on the Synchro set. All custom ratios wil be discussed one on one with me and will be done by the same time as the rest are. THESE CUSTOMS SETS WILL NOT DELAY THE REST OF THE SHIPMENT.
DOG GEAR SET: $2,200USD plus shipping from Florida
Main shaft
Pinion shaft
Crown wheel
1st gear
2nd gear
3rd gear
4th gear
5th gear
5th pinion
1&2 Hub
1&2 Slider
3&4 Hub
3&4 Slider
5th Hub
5th Slider
Synchro gearset (Stock SE-R or G20 ratios): $2,000USD plus shipping from Florida
I have added common translations for these parts because it seems that there is some confusion on what they are.
Main shaft
Pinion shaft
<-----input shaft
Crown wheel
<----final gear
1st gear
2nd gear
3rd gear
4th gear
5th gear
5th pinion
<-----5th input gear(it goes on the input shaft)
I notice a lot of people asking what else they need to replace. Well that sort of depends on how messed up your tranny is. Here is a the list of all other parts inside the tranny. I will be setting up a way for people to call and get (hopefully) special pricing on this stuff. Unfortunatly due to the varying amount of items you will all need in the tranny I feel it willl be easier for you to deal directly with the source for this stuff.
reverse idler gear
reverse idler bushing
reverse idler spacer
snap ring
spacer
I.S front bushing
5th gear needle bearing
baulk ring
coupling sleeve
spread ring
5th stopper
snap ring
I.S. bearing
M.S. front bearing
Steel ball
baulk ring
1st gear needle bearing
reverse main gear(just a coupling sleeve)
insert spring
1st and 2nd synchro hub
2nd outer baulk ring
2nd gear synchro cone
2nd inner baulk
2nd and 3rd bushing
3rd inner baulk
3rd synchro cone
3rd outer baulk
coupling sleeve
3rd and 4th synchro hub
insert spring
baulk ring
4th gear bushing
spacer
M.S. bearing
c ring
c ring holder
snap ring
snap ring
diff. side bearings
speedometer stopper
speedometer drive gear
DIFF
You will not need EVERY part, but you may need some. I will hopefully post today where you can get these fine, fine parts
With the Dog gearset you basically throw out all internals of your tranny and install the parts. With the synchro set it you use your synchro parts with the new gears. Cryo can be done, but par said it was not needed. They do everything to certain specs and did not recommend cryo-ing their gears. If you do want it and don't have access to the facilities I can have it done for you locally.
PAYMENT INFO:
All gearsets can be paid in full or 50% now and 50% prior to delivery. All payments will need to be postmarked by June 19th, 2003. This gives you approximatly 1 month to collect the money to send. I will contact you approximatly 1 month before the second payment is due to give you a reminder and time to collect the second 50% if you did not pay in full from the start. You will also be charged shipping at that time. If you live close to someone on the board that is in the group buy I will ship pairs of gearsets for the price of one. So if you get two sent to the same address I will only charge shipping on one. If you get 4 sent to the same address I will only charge for two, etc ,etc.
Orders should be sent to
PARGEARSET@HOTMAIL.COM. Please include the following data in your mail
Full name
Address
City
State
Zip
Phone numbers(a number that I can contact you at any given time)
what parts you want
how you would like to pay
what year and model(I obviously know the make
finally any questions or concern you may have.
Please input this data as close as you can to the setup I just stated above. Basically don't put it all on one line. I have delt with large dollar orders before and feel rest assured that your money will be safe. I have been at the same location for over 15 years and this is a concrete business not some guy working out of his garage. I have been mentioned or featured on NPM a few times and have been a long time Nissan community member.
I appreciate everyones paitence with getting this all setup. As you can understand this isn't has easy as a shift knob group buy where you pick one of four colors and thats it. If you need to contact me at anytime day or night(as some of you know when calling me at like 9:30pm at my house..lol(I know what you are feeling Dre..lol)) There is really no problem, just use common courtesy. My cell phone number is 813-376-5128 you will have great luck in contacting me via this number and if you leave a message I will get back to you within the day.
Once again sorry for all the confusion. Hopefully this will clear everything up.
Carlos
P.S.- if I forgot to mention anything please e-mail me with it.
SO FAR PEOPLE THAT HAVE SHOWN INTEREST:
stars have e-mailed me with purchase order
kesi24*
Thomas Reynolds
blackb13*
Coach*
