***EDITED***
5/19/2004 This Group Buy is over!. If you haven't paid and were in on the GB. Please check the third page on what to do.
OK time for Payments.
BlueEnyaMix@cox.net -my Paypal SN.
*if you pay by Paypal. Please remember to include the +.03% that paypal charges. So your total would be $12.36 for EACH plug.
Money order forms make them out to:
Chris Risling
910 S. 110th Plaza
Omaha, NE 68154
$12.00
After you send out your payment, please do this for me.
Email me. "BlueEnyaMix@cox.net" An type in the subject.
"Magnetic Oil Drain Plug payment sent"
An then in the email type your :
Name
Address
City, State, Zip code
Forum board you are on, and your SN on there.
An below that the form of payment you sent me.
I will save everyones email and use this so when I get the plugs sent to me. I have you address and can ship them out right away to you, an I will reply back with an email saying i've sent it out to you.
I will let everyone know when i've recieved all payments and have sent it to the person getting the oil plugs for us.
Thank you. Chris ******
__________________ PARTS Wanted:: Drivers side Front and Rear doors, an a rear bumper cover for a P11. Just need door shells. My car was side swiped. PM me if you have this.
This is from the guy I'm doing the GB through. This was on one of his Ebay sales of the Plug.
"The plug itself is machined from high quality steel and then a 'super magnet' affixed which is so strong that it actually acts as a very effective filter, pulling iron and steel wear compoments from the oil, reducing oil loading and oxididation rates. Plus, if something is going wrong in the engine, your drain plug will give you early warning! Transorms oil changes into engine wear evaluation! A must for banshee owners!" why let your motors clutch self destruct from metal shavings and contaminents being carried all over the inside of your high dollar expensive motor!!! This plug has a magnet on the tip end to collect and keep out of harms way all metal shavings/chips/powder created by the clutch and gears sets. This is the correct thread pitch and size plug that is just the right lenght to extend up into the oil and case compartment without interfering with any other moving parts. comes complete with a gasket and pre wrapped with teflon tape(as to make sure there are no leaks .the amount this magnet can and will collect in even just an hour or two of driving will amaze u."
__________________ In Loving Memory of ZAD,We LUV Ya ta Death, Save us a Spot Next To Ya Up There, we'll see you soon
He can make 200,250 or even 300whp! Because at the end of the day, He's not going no where but up and down Liberty Avenue stuntin for the rest of his fellow Indian friends!
__________________ '00 Q45 32 valves 4 cams and a ishh load of gas!!! '02 G20 Sport - 05 Maxima HID. AEM intake. R.I.P. '92 SE-R - Bruised with a few bolt ons R.I.P
I might be interested, but why would you need a gasket on a drain plug?
1992 Sentra SE-R
Still under 100,000 miles...racking up a whopping 200 a month! Mods: OBX header, ES motor mount inserts, WAI, 19* timing, Brembo rotors and Axxis MM, Clutchnet fiber/fiber clutch
To install: Hyperco Gen 2's
IMHO the gasket/washer doesn't need replacing. 200K miles, I did all the oil changes at 3K, never replaced the gasket/washer, no drips either. At 200K, I replaced the oil pan, 30K later, same gasket/washer no drips.
