I am very proud to introduce the new FTF Fuel Rail for the high port SR20, to be used with top feed MSD style injectors.
Working jointly
FTF Motorsports and
Custom Steel have developed what is possibly the BEST fuel rail on the market.
Made with some of the best fuel rail stock available, and machined to some redicilous tolerances, here are the highlights. Comes with all hardware, including fittings for
$100 shipped!! This is an introduction price and we will need 10 people to get this group buy going. If more than 10 people get in before the end of September we will offer this price until the end of the month.
*bling*
It comes standard with a brush finish, and for the show guys, or ballers out there, a high polish finish can be yours for $50 extra. It also has hot rod flames...and you know those add some serious HP!!!
Machined fuel injector clip reliefs to hold your precious fuel injector in place with no worries. We have also put in a fuel injector o-ring chamfer to aid with injector insertion...no other rail has this feature.
Since we are suppling all fittings, -6 AN to boot!!! We felt it important to make this as fool proof as possible, therefore we have invested in producing the correct port for the o-ring boss on the ends of the rail. This allows the o-ring boss fitting to seat properly and assure a leak proof seal. Once again, this is the only rail on the planet with this feature for the SR20.
O-ring fitting partially seated.
O-ring fitting fully sealed with a couple of turns of the wrench.
If we weren't cool enough already, we are also providing 5/16" (8mm approx) barbed hose fittings that attach directly to the -6 AN fitting if you arent cool enough to have SS fuel lines and just want to run stock rubber hose. (hose clamps not provided)
As stated before, all hardware will be provided to make this rail plug and play. The only thing you need is your FPR of choice, and fuel lines. Not pictured are the fuel rail brackets that will attach this rail to your intake manifold. These will be included as well.
So to recap, what you will get for your hard earned $100 is (1) FTF Fuel Rail, (4) Fuel Injector Clips (MSD style) (2) -6 AN to O-ring boss fitting, (2) 5/16" (8mm) to -6 AN barbed hose fitting, (2) Brackets to attach fuel rail to the manifold, and (2) bolts to attach brackets to the fuel rail. You will use your existing fuel rail bolts to attach this to the intake manifold. Dont forget thats $100 shipped via UPS Prority Mail!!
Ill answer some questions before I get bombarded....
What if I have a lowport? - Dont worry, in another month or two, we will be launching our lowport version of this rail.
Damn, Im not super cool and im running a stock FPR, what then? - Sit tight!!! The next rail comning out shortly will have a built in port for the stock FPR. Unfortunately this piece will be a bit longer than this one and will cost slightly more, expect this around the end of September.
Ive got a GTiR motor, why do companies make me feel alone in this world? - We are not ignoring you, as a GTiR fuel rail is under development, we need a GTiR intake manifold to do some fittment testing, if you have one, let me know.
Where should I make payments to? - All payments should be made to FTF motorsports, please contact Terry at
terry.vincent@ftfmotorsports.com to find out what options you have.
When is this deal over? - We need 10 people to get this going. If more than 10 are serious about this, the price will be good until the end of September.
I dont have much money right at this moment, what is the normal price? - Normally this rail will sell for $120 plus shipping, so your gonna save at least $25 by getting in on this deal now.
What does this look like installed? -
Check out Rob's setup. This is of the previous generation fuel rail with some hella cool AN fittings and trick FPR attachment points.
Thanks for your time and support. This GB is also being advertised on
www.G20.net and we will combine all persons intersted to make up the 10 needed.
