i will be parting out my 96 se-r and anything and everything will go here is a list of the mods i would like to sell
motor with 81k on it it has tomei 256 w/11.5mm lift cams in it with only 4k on them it ran beautifully till i crashed the car and it did run after i'll sell it with the harness or with out i am looking for $550 w/o those cams and some stockers in place or $800 w/ them i also have the comp cams valve springs in the motor which i will not remove. i can sell it with the harness and ecu if necessary for $600---motor might be sold but the harness is gone.
i will sell the cams seperately for $300 they are in great condition---cams are sold
tranny with 81k on it it has a new act extreme pressure plate with a street strip disk in there installed 4k ago i would like $550 for it with the clutch attached or $400 w/o it. if someone is looking to do an auto to manual swap i will pull all necessary gear for it and sell it with the tranny for $650 with the clutch --- clutch is sold as well as the tranny and flywheel
tein super street dampers with 15k on them they are in great shape i absolutely loved this set up $800---sold
Ground Control camber plates 15k on them great shape also with them I trimmed the power steering bracket that mounts on the right shock tower so that they both fit nicely $275---sold
UR pullies the crank and water pump in aluminum polish $150---sold
NX2000 front brakes (ADV22F) with 20k on them painted red calipers with a new set of pads the disks the rotors $100---sold
complete rear disc brakes with all lines and e-brake cables for any one doing the swap $80---the e-brake cables and brackets are sold not the discs or calipers.
suspension techniques sway bars good condition the front one has a little road rash but still very very strong $ 100 for both---sale pending
seats i have two nx2000 front seats in good shape $80, two classic SE-R fronts in good shape $90, and the whole set of 96 SE-R seats front and rear in very good condition $150--- sale pending for the b14 rears
the arm rest for the b14 $40 great shape if you do not have one you need one it makes the long drives soo much more comfortable---sold
the bubble taillights from a '98 200sx for $90 in good shape
the sideskirts in good condition in aztec red $50
trunk lid and wing $50---sale pending for the wing only
custom short shifter works awesome i made it $30---probably going with the shift linkage unless someone wants it
a 94.5 G20 OBD2 ECU it is for an auto but it works on the stick car it just throws a cel i drove with it on forever and it worked fine. $80---sold
factory ecu $80 if it doesn't go with the motor
water neck drilled and tapped for a temp gauge w/ the sender $50---sale pending
wheels in good condition a little curb rash on them with okay tires for $400
if anybody is interested i'll sell the rear beam i had it bent by 98sr20ve it has exactly 0 degrees toe $50
I will be working on getting pictures hopefully for this weekend. i would like buyer to pay most of the shipping but on larger heavier items i'll help split the cost with buyer. obviously any local buyers would be much easier for the both of us. i am currently stationed in baltimore maryland. i have paypal and would like to recieve payment that way but will accept cash or money orders. i am negotiable on prices as long as they are realistic if my prices are not realistic then we can talk. my car was kept up very well by me so i am confident that all parts that i sell will satisfy there new owners. and if there are any misc. stuff out there that you may be looking for just ask and let you know what is up with it.
thanks for viewing.
Eric
'02 G20 5speed sport edition in white, so pretty!
'00 Honda VFR Intercepter 800FI the cheap way to low elevens
'93 white classic the new toy getting ready for the funny stuff
what condition is the wing in? (Only interested in the wing)
I'd like to use it to replace mine (clearcoat bubbled & cracked)
any idea the shipping to 76103?
Gary K gary245@hotmail.com
i failed to mention that i already did the mod to the distributor to hook up an MSD ignition but if that doesn't bother you then i'll sell it seperate, you are second for the rear beam. and i think i would like $80 for the distributor i think that is reasonable.
Originally Posted by Teal97
how much for the distributor? i may be interested in the 0* toe rear axle also. pm me
the wing is in good condition it has a small scratch in it but i think with a little attention it will come right out and i'll sell it seperate for $50 only because it will be more difficult for me to sell the trunk lid now and i'll look into the shipping.
i started to have some wear on the top of the shift boot ring so what i did was cut an inch or two off of the top of it then work the elastic and ring down on it so that it would conceal it, now i have a pretty short shifter in there so it would probably not accept a stock shifter but if you would like to purchase both i'll sell the shifter and boot together, you can't tell that i moved the ring. i would like $50 for the set or $20 for just the boot
Originally Posted by sxsenis
How about the leather shift boot trim ring. Is it for sale also. Only if its in good shape no holes or bad wear marks.
the tires are mismatched like crazy i got two sumi tomo's with about 50% left one falken azena thats shot and another one that is 95% i'll try and get pics up of everything for this weekend. i got alot of work to do! how far is frederick from baltimore come check them out the car is right off of route two in pasedena then you can vouch for the rest of it for me!
Originally Posted by billc
What kind of tires are on these wheels? Got pictures of the wheels?
just to give everyone a heads up i amtrying to put the dibs in cronological order so i think this is what i got
rear beam 1. webninja, 2. serfanatic, 3.teal97, 4. foolishwaz33
water neck 1.serfanatic
swaybars 1.espsound
rearbrakes 1.ayrtonsennad, 2. foolishwayz33
clutch 1. foolishwayz33 just about sold
distributor 1. webninja, 2.teal97
wing 1.gary245
front brake set up 1.neva2wicked
rear seats 1. nismo_99
now that is what i think i have up to date if i have missed anybody i apologize. i am working diligently to get everything ready to sell. i have this whole weekend and all next week so i should be all set. i do not own a computer or digital camera so my responses may be slow and i apologize or that i am also trying to get some pics up as soon as possible. for people looking to do local pickups on parts you can call me anytime at 860 995 4159. i will still keep the dib order fair with local pick ups as well. i appreciate everyones attention to my ad and i hope everyone can get some parts and enjoy them.
eric
