Item for sale: Engine Components for Sale
Price: $20 and up + Shipping
Condition: used
Shipping:
- Local pickup only
- Continental
- All US
Acceptable Means of Payment: paypal / cash / us postal money order
Contact Information: sbtech10 at gmail dot com
Description:
I have some Highport parts for sale. The heavy stuff will be expensive to ship so keep that in mind. I don't mind delivering to my surrounding area NC, SC, AL, TN, Northern FL, All of GA. If I deliver I will need money for fuel expenses. I can provide pictures of anything in this thread so just ask. Mileage on these parts are unknown as they come from spare engines I accumulated over the years. The motor internals are for rebuild only, as they will need prep work.
Two SR20DE Grey Valve Covers : $20 each
Two Highport USDM Intake Manifolds: $30 each
Two SR20DE 8CW Crankshafts with pulley, spacer, and gear: $50 obo each
Info on Crank 1: Marked 12101 and 1111 below the first number. I think it came from a motor that might have had a blown head gasket as the oil looked gooey. No signs of rod knock but wear marks on main journals.
Info on Crank 2: Marked 02221 and 1111 below the first number. Signs of rod knock on cylinder number 1. Head attached to this motor had some signs of sludging so the engine was probably old.
Two USDM SR20DE highport heads no camshafts: $30 obo
Picture of one head. Still need to get a picture of the other head.
Two USDM Highport Blocks: $40 obo
Info on Block 1: Comes with girdle, main caps, main cap bolts, front cover, both oil pans, timing chain. This block is marked 12222 and was using grade 2 pistons. I think it might have been a victim of a blown head gasket. Cylinder walls will need to be cleaned up.
Block 1
Block 1
Info on Block 2: Comes with girdle, main caps, main cap bolts, front cover, both oil pans, timing chain. This block is marked 032223 and was using grade 2 pistons. The block suffered rod knock on cylinder #1. Cylinder walls will need to be cleaned up.
Block 2
