I'm Parting out my 1991 nissan sentra se-r. Second time i'm posting. It has a gti-r motor. This is the list
Gti-r motor with new oem headgasket and arp head studs/bolts(needs piston rings) $500
complete gti-r turbo setup (t28 turbo, gti-r manifold, down pipe, oil and water lines) $700
jwt ecu tuned for gti-r(Upgraded ECU programmed to eliminate speed limiter, raised rev, timing and fuel slightly adjusted for WOT)$150
lsd tranny no issues $300(sold)
444cc gti-r injectors $150
Greddy 20g turbo with xspower manifold and 38mm wastegate $600
1991 se-r wiring harness $100
2 intercoolers $50 each
Complete 2.5 inch turbo piping $80
greddy turbo timer $70
two axles $40 each
2 sets of rear disk brakes set up $80 each
full 2.5 inch bolt on exhaust system with magaflow barrel $100
sunny single fog front bumper with 626 lip as seen in pic $400 (SOLD!)
Se-r interior $60
15" Maxxim ahead rims with good tires...grips good $500
New radiator $60
AutoMeter Boost and Oil pressure gauges with dual gauge pod $75(SOLD!!)
HKS blow off valve $50
Walbro 255fuel pump $80
USB to consult cable with software included (used for data logging and diagnostics) $make offer(SOLD!!)
Whiteline springs(front installed back still brand new about a 1"-1-1/4" drop) $100
upgraded clutch less than 3000miles(Stage 1 Street/strip clutch) $100
The car was a 100% running car so anything that you need that will be on the car is there. I will update as parts gets sold.
http://www.sr20-forum.com/redirect-t...-26-42_336.jpg
