A/C STUFF-Everything under the hood
I pulled all of the A/C related crap off of my 91 SE-R. I am selling the following.
Compressor, brackets and bolts.
High and low side lines
Heat exchanger
Belt
Secondary cooling fan
O-ring kit
2 cans R134a
Recharge hose with valve and guage
Basically everything a/c related under the hood, nuts, brackets and otherwise. The high and low side lines have been converted to R134a so the adapters are there. Also included is 2 cans of R134a and the recharge adapter which has the line, valve and guage on it. The system was NOT working when removed. I was in the process of updating it when I decided to just remove it. All of the equipment was working on R12 as of early summer 2003. I think the low pressure switch is bad but I never got that far. The compressor spins and makes compression so it should be ok. AS IS though because it is OLD. Anyway, you pay for actual shipping(Which I will get to you based on ZIP). Tracking number will be provided. Not sure what it's worth but if interested PM an offer.
thanks.
H8
The 91 is gone
Project 96 on hold for now
