Looks awesome Chris. So did that car start its life as a E or XE? Any gains from that intake mani? Looks insane. As long as its functional. Keep us updated.
The car started out life as a very base model E (so only the 1.6, rear drum brakes, no power anything and no sunroof!!)
...the brakes were the 1st upgrade before the engine upgrade (infiniti G20 rear brakes with g20 rotors redrilled and AD22vf front brakes with Maxima master brake cylinder of course)
...had to change out to KYB shocks/struts since the stock E had no provision for sway bars from the factory.. added ADDCO rear sway bar and stock SE-R front sway bar...
..SR20de swap happened and then work on the cage....
NO tests done yet on the intake since it will be changed again.. ..should have run a baseline but forgot... ...ooops...
