Here is my dads car, he funded the project I put her together, the car has not left the garage since I bought her for $500 with a blown motor 3-4 years ago, she has since gone a motor swap, the motor is....well you can tell by the pictures:
Mods Include:
ENGINE:
GTI-R DET
50# MSDS
Nismo FPR
Aerospeed Fuel Pressure Gauge
JGY Customs fuel rail
JGY customs 6 puck clutch
B15 Tranny
JGY Customs 8# Flywheel
DIY Front Mount Innercooler Setup
Koyo Radiator
Flex-a-lite slimline fans
Prothane Motor Mounts
Relocated power steering cooler
Full 3 inch exhaust with a magnaflow muffler
Custom Short shifter
Walbro 255hp fuel pump
JWT ECU
Cobra MAF
Turbo XS RFL BOV
SUSPENSION:
Energy suspension hyperflex kit
Whiteline 4pt brace
All new ball joints
All new upper strut mounts
all new inner and outer tie rods
KYB GR-2 Struts
Cusco FSTB
Active Tuning RSTB
Brembo slotted and cross drilled rotors
Stainless steel brake lines
Hyperco springs
All new hubs and bearings
INTERIOR:
GTI-R red gauge needles
3 pod gauge pod on the a-pillar with sunpro gauges to match the factory gauges (boost, air\fuel ratio, amp meter)
B14 HVAC controls
Pioneer head unit relocated to the empty cubbie hole above cup holder
GTI-R gauge pod in the stereo's stock location, GTI-R gauges replaced with sunpro gauges to match the rest (oil pressure, oil temp and voltage)
SE-R front seats
Greddy turbo timer
Nismo shift boot
Manual to power window and lock conversion
Python security alarm
Black suede recovered back seat, door panels, and rear cargo cover
Auto Power roll bar (painted a silver brushed aluminum type color)
EXTERIOR:
Custom GTI-R style hood
NSX Functional Side Scoops (Rear Brake Ducts)
Carcept Bodykit
Blacked out side markers, front turn signal lamps and rear taillights
VW Golf Black Projector Headlamp conversion
Shaved front antenna
Shaved rear wiper and squirter.
Shaved side door moldings
More to come......
I have alot of plans left before she gets painted black diamond metallic and the finished product may not be for everyones tastes but thats ok. I have come so far but still have alot left to go, tell me what you think.
