Recently purchased Team Dynamics Pro Race 1.2 15x7 +35mm rims through fastbrakes (since Brian test fit them for me). Hi-power silver (yo!)
First, they ship directly from Tead Dynamics in CA and they use DHL. I had some damage issues with this combination. Team Dynamics did take care of it, but you may want to ask for extra protection and a different carrier.
11.75" SMC babk with 4 piston wilwood billet dynalite calipers, should be very similar to the fastbrakes kit. Have 1.5-2mm of clearance between the outside of the caliper and the inside of the rim. There is plently of spoke to caliper clearance.
The car will be washed after I leave work, but I needed to use my work digital to get pics, so forgive the garage dust.
click for larger pics
1994 SE-R track car, VE, brakes, etc
2007 MazdaSpeed3
that looks great... much better than my 11" kit under my 18's ... I need like 14" brakes to look that good on the street I got some 15's to look good on the track cant have both worlds
__________________ Silver '96 200SX SE: fresh '98 GA16, I/H/E, JWT Turbo Clutch & Flywheel, Motor Mounts, Prokits & GR-2s, 11" FastBrakes, 18" OZ Cronos Parts waiting to be installed: JWT ECU, Hotshot turbo kit minus the potato. Anyone have a good T25?
I read a thread or two by you on which rims fit the brakes, but went with these instead after fastbrakes confirmed they would fit.
Thanks to everyone else for the comments!
Guess we can add one more wheel to the list
Oh yeah, I just ordered my Pro Race 1.2's in a 30mm offset, black, with the wheels being bored out to 59.1mm. The bad news, I had to sell a set of my ATS wheels
Are you guys buying these directly from fastbrakes? How much per wheel?
I actually went through Brian at Good-win-racing.com. I've spoken to him in the past about these wheels. I paid $109 per wheel, plus $10 per wheel to bore them from 54mm to 59.1mm, plus shipping... not to bad on price.
