Old 08-03-2006, 06:03 PM   #1 (permalink)
SHIFT_e
pyrocrickett's Avatar
'92 "F13" Stealth Fighter!
My GA16-powered F13 stealth fighter! (more pics)
At least, she will be a stealth fighter when I'm done with her... right now she's just... stealth.
I have a lot of mods coming that will severely improve her handling & give a lil' bump in performance,
too! I'm really excited to get my baby all done up right & start carvin' up some cones!
Mods done:
**UPDATE: White LED instrument backlights!
Addco rear & OEM SE-R front swaybars
Redline Goods leather shifter boot
B14 rims w/205/50 Falken ZE512s
homemade lower control arm brace
grounding kit
2" cat-back w/MagnaFlow muffler & 18" resonator
AGX/CG suspension setup
solid shifter bracket
nismo shift knob
SE-R cluster swap
1.62" shorter shifter
ES shifter bushing
Advanced timing to 15*
Homemade CAI
Planned mods:
(on there now => planned upgrade)
Suspension
Wheels------------------ DONE! stock => B14 15" alloys: $247.20
Tires-------------------- DONE! all-season => high-performance all-season: $361.09
Struts & Springs --------- DONE! stock => KYB AGX w/ GC coilovers: $300
Bumpstops--------------- TBA stock => Ground Control progressive soft: $58.21
Swaybars---------------- DONE! none => OEM SE-R front & Addco rear (with ES bushings): $181.35
Lower control arm brace-- DONE! none => home-fabricated bolt-on: free!
Drivetrain
{Crank pulley---- stock => UR lightweight} UR doesn't make B13 crank pumps anymore
Intake spacers-- none => Outlaw Engineering spacers: $109
Grounding kit---- DONE! none => Mautai916's custom set: $25
Shifter bushing-- DONE! stock => Energy Suspension polyurethane: $14.38
Shifter bracket-- DONE! stock rubber => solid steel: $4 for nuts & bolts
Intake---------- DONE! stock => homemade CAI: $65.31
Exhaust--------- DONE! stock => 2" custom cat-back: $176.99
Muffler---------- DONE! stock => 2" Magnaflow XL: $43.57
Resonator------- DONE! stock => 2" dia, 18" long Magnaflow: $55
Interior
Instrument cluster-- DONE! stock => OEM SE-R (finally! a tach!): $30
Cluster backlight---- DONE! stock => white LED bulbs: $16.82
Shifter------------- DONE! stock => modified stock (-1.62"): free!
Shift knob---------- DONE! stock => nismo leather knob : $36.05
Shifter boot-------- DONE! stock => Redline custom leather boot: $42
Exterior
Front lip---- none => Mazda 626/MX6: $30
Total cost: $1795.97
If anyone has any suggestions, lemme know!
(No, I won't do a 1.6-2.0 swap and I'm gonna stay NA, so don't ask! )
Proud GA16DE Driver No More
Now I'm driving something a little different...
It's more fun to drive a slow car fast than a fast car slow.
pyrocrickett is offline   Reply With Quote
Old 08-03-2006, 06:24 PM   #2 (permalink)
The Groove Master
Rittmeister's Avatar
Sounds like you have some good plans.
Go get a timing light. You CAN damage the engine over time if the timing is too far advanced.
1990 240SR - the DET has landed.
Kent's Funkay Disco
Old 08-03-2006, 06:31 PM   #3 (permalink)
uh ok then why ane you on the SR20FORUM
davy is offline   Reply With Quote
Old 08-03-2006, 06:37 PM   #4 (permalink)
Gone!!!
Trader Rating: 24 (100%)
Shut up, noob.
Welcome to the forum, Pyrocricket.
93 NX2000 VE
08 Frontier Se
BORNGEARHEAD is offline   Reply With Quote
Old 08-03-2006, 06:40 PM   #5 (permalink)
i smell that whore.
Trader Rating: 32 (100%)
yes, that would be a good idea.
jeffinbham is offline   Reply With Quote
Old 08-03-2006, 06:50 PM   #6 (permalink)
Travieso Racing
blow that sh*t up or... put an SR20DE engine in it
Danny GDM (HKS)
1993 PRiMERA GT
Old 08-03-2006, 06:51 PM   #7 (permalink)
SHIFT_e
Shut up, noob.
Thanks, BORNGEARHEAD
Old 08-03-2006, 06:53 PM   #8 (permalink)
SHIFT_e
I'm gonna keep my B13 true to it's roots, man!
Old 08-03-2006, 08:30 PM   #9 (permalink)
SHIFT_e
Update! See post 1!
Old 08-03-2006, 08:32 PM   #10 (permalink)
More details/pics on the CAI? I saw the ones in your gallery.
thejaredhuang is offline   Reply With Quote
Old 08-03-2006, 08:34 PM   #11 (permalink)
SHIFT_e
What more are you wanting? I'll gladly take any pics and explain anything you're not clear about!
I got all of my information/inspiration from Nostrodomas's CAI, so I'd recommend reading that first!
Old 08-03-2006, 08:42 PM   #12 (permalink)
Chubby business
Trader Rating: 18 (100%)
I really think you need to turbo it or put a SR in it..........
Originally Posted by evilsr20degg
ugh this is so rediculous why would they cklose bars at 2?
i jhust ran outta beer at the house wtf do i do now?
My buddy with a donut shop can hook you up. He goes through a deep frying process that gives the pistons a crispy crust , then he either coats them with a low friction glaze, or a lubricatn absorbing powerder. Mmmmmmmmmmm... Pistons
TheRealNightHog is offline   Reply With Quote
Old 08-03-2006, 08:43 PM   #13 (permalink)
SHIFT_e
See post 8
Besides, aside from being my DD, I'll be autoXin' the F13, so I'm focusing all of my tuning on suspension performance.
Old 08-03-2006, 08:44 PM   #14 (permalink)
Sc61 in works
You said you are going to greatly improve the performance of the car. Yet you are going to stay NA ga16 NA.......
Goodluck improving performance.
Sc61 Se-R Sold..
Originally Posted by SlidewayS15
Isn't the Sentra A FWD.....The SR20det is a RWD motor
Originally Posted by Salvisol82 View Post
I'll Tell you one thing. Jenna Jameson has one of the ugliest looking vaginas I've ever seen. From a lower front view it looks like she has a tiny nutsac.
B14 Se-Rious is offline   Reply With Quote
Old 08-03-2006, 08:51 PM   #15 (permalink)
SHIFT_e
Lol... I guess that statement was a bit misleading about my intentions; more clearly, it should've read:
severely improve her handling, and performance will be getting a little bump, too!
The only pure performance mods I'm intending to do will be primarily bolt-ons: a full CAI and exhaust for freer breathing, possibly UR pulleys all-around, and maybe, maybe better cams. But like I said, I'll be mainly focusing on handling!
Old 08-03-2006, 09:00 PM   #16 (permalink)
Sc61 in works
thats cool your going to focus on handling, btu even with all the handling you do.. you are taking a 90whp car to the track. You will get passed by every car in every corner, every straight, anywhere and you will quickly get bored with it.
Its just like buying a Ninja 250cc.... after 1 week its on the market to be sold.
Old 08-03-2006, 09:27 PM   #17 (permalink)
what about an SR16VE? that way you technically still keep the 1.6L LOL. Smoke peoples doors off.
itsbrokeagain is offline   Reply With Quote
Old 08-04-2006, 01:07 AM   #18 (permalink)
The DET is in!
Trader Rating: 17 (100%)
That turned out pretty nice. Your welcome lol.
Don't diss the GA16 guys, with full bolt ons and cams the GA16 can put out some power. You have to remember the car, and the engine weighs less.
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 08-04-2006, 01:15 AM   #19 (permalink)
Chubby business
no it doesnt.......
Old 08-04-2006, 01:33 AM   #20 (permalink)
The DET is in!
Yea actually it does... It can put out more then the stock SR20DE does.
