1993 SE-R: The "Grey Goose" is now SOLD
Officially Retired as of 11/30/07; Sold 12/06/07 - Long Live the Goosey!!!)
For Latest Pics of the "Grey Goose!" (Dubbed by HkSBlueBird4u) Check The Last Page or: Click Here For the Gallery!
Introduction:
Simply put...
My
First Fast DE,
First DET Swap,
First Stripped B13,
First Run with the Cops
First 13 second Car
First NX Brake Stop
First Broken Clutch Cable
First Radiator Rust Rot
Special shot out to all my boys who helped get this car where it is; whether it be doing two swaps in two days, sticking it out to help me put things on, letting me stay at their crib, to borrowing tools, borrowing parts... Thank you... "Haaaaaoooooonk!"
Table Of Contents/Index: Page 1: General Information | Modifications | Work Goals & Accomplishments Page 2: Nothing Special... Page 3: Interior Work | Replacing Dash | P10 Stereo Install by Brennan | New E-Brake Lever Page 4: New Seats from Ryan/Kent | Door Panels Page 5: New Bunk Speakers and Connector Hookup Page 6: Junkyard Trip | Apolstery & Headliner Install | Exterior Pics | Stock Shift Knob Page 7: ser91's Car (Sam) | New ES Bushing Kit Purchased Page 8: The Hoe-E-M Baby | Refurbished B14 Powdercoated Rims Page 9: New 1993 Driver Side Tail | ES Polyurethane Bushing Kit | U13 ECU | New Blower Motor | Blower Motor Install Page 10: New After Market Foglight Test Fitting Uh Oh! Page 11: Surprise Surprise... Page 12: U12 Nissan Bluebird SR20DET Page 13: Complaining of Body Ache & More Bitching... Well Deserved Page 14: First Video Footage Post Turbo Motor Install Page 15: The Infamous "Long Story": Chapters 1-4 Page 16: The Infamous "Long Story": Chapter 5 | A Few Outside Pic Page 17: New C-Pillar Covers Painted | Got my car Back!!! | Fixed my Downpipe Leak | The "Batcave" Page 18: C-Pillar Refurb | B13 LE Headrests in the B14 | GP STE Turbo Emblem Page 19: Post Detail Pictures, Dents Galore | All-Trac Hood Scoop Test Fit Page 20: Missing front MM Bolt | The NEW Hoe-E-M Rims!!! | New Pictures Page 21: Start on the Poorman's (R) Hood | Turbo Timer & Shift Light Purchased | Suspension Parts Page 22: Work on the Hood | More Turbo Parts: Used IC Kit & Poorman's (R) Boost Controller Page 23: Downtime! | Walbro 255 Fuel Pump & Nismo FPR | New Pics!!! | Hood Almost Done!
Brakes & Suspension:
-15"x7" Rota Sub-Zero's w/ Falken Azenis in 205/50/15
-NX2000 Front Brake Calipers
-NX2000 Drilled Front Rotors
-BFGoodrich Stainless Steel Lines
-Eibach Ground Control Coilovers (300F; 250R)
-KYB AGX Adjustable Shocks
-RNN14 Cusco Front Upper Strut Bar
-B13 Front Cusco Camber Plates
-Active Tuning Rear Strut Tower Bar
-EBC Brake Pads
Electronics & Data Logging
-Impakt Nissan Data Scan Monitoring Device
-Calumsult for Calum Daughterboard
-AEM UEGO Wideband O2 w/ Bosche Sensor
-Apexi Full Auto Turbo-Timer
-AC Autotechnic Boost Gauge
-AC Autotechnic Oil Pressure Gauge
Appearance & Cosmetics:
-Free Dents and Dings
-Custom Powdercoated B14 Wheels (done by Sinistersntra91) Winter
-15" Rota Sub-Zero's w/ 205/50/15 Falken Azenis for Warm Months
-Nissan Stanza Steering Wheel
-Bumper/Support Cut for FMIC
-Celica All-Trac Hood Scoop Molded (RIP)
-WRX STI Hood Scoop (Thanks Rodney!!!)
Weightwatchers Mods
-Removed Air Conditioning
-No Sunroof (Stock)
-Removed All Cruise Control
-Removed Sound Deadening
-Removed Insulation
-Hood and Trunk Webbing Removed
-Trunk Carpet Removed
-Spare Tire Removed
-Air Bag and Hardware Removed
-Rear Seats Removed
-Headliner Removed
-C/Pillar Covers Removed
-Hood Latch Hardware removed... sigh
-Battery Relocated to Trunk
-Broken & Removed Antenna (Now Hidden in A-Pillar)
Stereo:
-Cheap Ass Sony Detachable Face and Two Generic Speakers
Work Complete:
-Install P10 OEM CD Player (Thanks Brennan 01/13/07 )
-Change Blower Resistor (Done by Owner... Fixed 01/13/07)
-Carpet Replaced w/ Black Carpet from Donor Car (Owner!)(Fixed ??/??/06)
-Replace SE-R Rear Seats (Complete 01/17/07)
-Replace E-Brake Lever (Complete 01/21/07)
-Fix Driver Side Lock (Plastic Clip was Off... Fixed 01/15/07)
-Replace Driver Side Vent/Dash (Fixed 01/15/07)
-Put in Front Speakers (Complete 01/22/07)
-Replace Center Dash Piece (Fixed 01/15/07)
-Replace Passenger Side Door Latch(Fixed 01/27/07)
-Install a Headliner & "Oh sh*t" Handles (Fixed 01/28/07)
-Replace Spare Tire (Fixed 01/28/07)
-Replace Blower... (Fixed 02/03/07)
-New Rubber Mats ($8 @ Wal-Mart!!!) (Fixed 02/04/07)
-u12 Bluebird SR20det swapped (Completed 02/17/07)
-Changed Spark Plugs and Swapped NGK Blue's in (02/19/07)
-Regapped Plugs to 0.030 in. (03/03/07)
-Installed Lotek B13 A-Pillar Pod (Boost/Oil Pressure) (03/03/07)
-Replaced Cracked Driver Side Outer Tail Lamp (03/03/07)
-Installed Refurbished/Powdercoated OEM B14 Wheels (03/18/07)
-Cut Bumper Support for IC (??/??/??)
-Replaced PS Pump, Removed A/C Compressor, Oil Change (04/21/07)
-Refurbish All Trac Scooped Hood, Paint, & Install (5/08/07; Wrecked 5/12/07)
-Install RNN14 Cusco Front Strut Tower Bar(03/18/07)
-Install S13 Steering Wheel (05/20/07)
-Install Ground Controls & Cusco Camber Plates; Raise Car (05/20/07)
-Removed All-Trac Hood... sigh, and Replaced w/ Stock Hood w/ STI Scoop (06/09/07)
-Removed Cruise Control Cable, Vac, and Solenoid? (06/09/07)
-Cut/Reweld Intake Section & Install Front Mount IC & Piping (07/07/07)
-Install Homemade Fuel Pressure Gauge Kit (07/07/07)
-Install Nismo Fuel Pressure Regulator (07/09/07)
-Replaced Driver Side Axle RRRRRRrrrrrr (09/08/07)
-Installed 3" VRS Downpipe & Attemted Exhaust Help (09/23/07)
-Installed AEM UEGO Wideband 02 Sensor (09/25/07)
-Removed Old FMIC Piping and went back to TMIC (10/04/07)
-Installed Apexi Full Turbo Timer (10/12/07)
-Sold :sad: - 12/06/07...
Work to be accomplished:
-None... the car is no longer mine...
What the Future Holds
-New Chassis for your Boy...
-Pulsar GTIR T28, Mani, J-pipe, Water Lines (Purchased)
-Nissan Injectors Resized to 550cc by RC Engineering (Purchased)
-Brian Crower Stage 2 Camshafts (Going IPS Motorsports)
-Calum Chips for my identical u13 program reflashed for 550cc @ 4bar
-Brand New Falken Azeni 615's or BF Goodrich g-Force R1's :druel:
-14psi of daily rice *** whipping goodness.
See you next Spring!!!!! New Chassis - 300whp or bust!!!
It's the Grey Goose!!!!
Latest Interior Pic
Wait a minute? Is that a TURBO Sentra? That got a Es Ar Twinny in it ...
Most Current Under the Hood $$$$ Shot... (07/07/07)
fu*k man, that thing is NICE, but you its gonna be asked, so i'll do it
how much did you pay...
