Just finished installing the B14 belts on the drivers side, I'll get the passanger side tomorrow night . Oh yeah, I love these so much better than the auto-crap belts that the 240 comes with...
The one mod that needed to happen for this to work, drilled a hole large enough for the tab to fit in.
Reused the hardware from the rear seatbelts on the 240. I'll add the B-pillar plastic piece once I have a harness bar built and the seats figured out.
The lower mount for the belt goes right where part of the auto lap belt was previously located. I did cut the carpet so the belt can go through.
And what it looks like installed... much better if you ask me . Of course the car does still look alittle bare
There is a 7lbs weight difference between the B14 belt and the S13 auto belt... so chalk another 14lbs off the car
question time:
som im going to try to install a NX seat belt today in the coupe, and you said you needed to drill a larger hole for the "tab"? what tab are you talking about?
Look at my first picture again, you'll see a tab on the top bracket on the belt spool... I guess you could just cut the tab off, I decided to drill an extra hole for it.
also, when you did the 300zx brake upgrade, do the calipers bolt up? or do you have to use different spindles? if no, did you press in the 5 lub hubs?
also, do you know if you can press in the s14 5 lug hubs and run the s14 5 lub rotors with the stock s13 calipers?
just a thought i had lol
i want to do 5 lug for better wheel selection
ahh. ok i see it now. thanks
Got alittle more done the last few days... Since the JDM mother-in-law is here and settled in I can get back to the garage a bit more now .
The automatic pilot bearing was a pain, but did come out once I used some brute force. Found that a 14mm deep socket is a somewhat tight fit for the ID of the bushing and using a 5lb sledge to basically walk the bearing out was easier than I thought.
The best way I could find to torque the flywheel bolts without a helper... gotta love the craftsman prybar!
The tranny slid back on with ease... once I got the motor off the ground by 1/4" at least. It just two stabs and it slid all the way up to the motor, and this was with no helpers.
I got bored waiting for my friend to show up, so I thought I'd see how far I could get...
Still waiting for my friend to show up...
Decided to wrap my short SS line for the oil pressure sensor with some fiberglass sleeving before I forgot.
Getting the motor onto the mounts was so quick and easy, I knew something had to be wrong. Oh, I did have my helper for the final drop, no way that was happening by myself. As I thought, we realised that the JGS motor mounts we're marked wrong and we had to lift the motor back up to rotate the mounts 180 degrees, thought something was wrong when we saw the oil pan nestled tightly into the crossmember!!! Oh well, it's all in now and I can start reattaching sensors tomorrow night.
1991 xe..dead(boneyard)
1994 e..dead(parted out)
1993 nx2k..dead(road kill hit by a f150)(parted out)
91 sentra E HIEPDTO^UFSW..dead
2007 hyundai accent DD
1987 pulsar se AWD-T 1.6 4wd non turbo in the future
1987 sentra wagon(4WD) soon to be the DD!! and future gtir motor/tranny swap awd-t FTW www.lubedealer.com/dkinney
for all your AMSOIL Synthetic Oils and Filters
