Thought id share my project with you guys
1984 Toyota Starlet
Out with the mighty 4k(1300cc of pushrod 8 valve fury)
I got a sr20de+5speed from an s13
Engine as i purchased it
Now the sr20 is alot bigger than the 4k and requierd a bit of thinking an modifying to fit it in
Test fit
here its sitting very high as the stock angine mounts are in the way.
I ended up moving the engine back quite far which involved cutting a bit of firewall and gearbox tunnel
Starlet gearbox(K50) and silvia gearbox
sr20 clutch plate is the same size as the 4k flywheel lol
Went to get a ceramic clutch and found the engine has a det flywheel.
So i got a 6 button ceramic sprung center with a heavy duty pressure plate
engine mounts tacked up
engine sitting in final position. the bonnet doesnt close anymore so ill have to mod it
crossmember all welded an painted
honda hrv radiator mounted on an angle as there is no room behind the bonnet crosmember
got some bigger brakes and struts off a toyota cressida
because the struts are bigger i now have positive camber. Im making custom control arms to solve this
bosch 910 fuel pump
link lem G3 ecu. this is made in new zealand and is a great little unit. its Map sensored so no stupid afm(maf to you guys). can handle up to ~22psi boost.
the best thing about this ecu is its got usb onboard and has great software. also it has digital trigger decoding so one ecu can run reluctor, hall effect or optical cas without needing sub boards.
This car s being built as a gravel rally car so is getting a cage and harnesses etc.
cool thing about new zealand modifying laws is that we can do just about anything to our cars and also have very lax emissions. we dont need catylitic converters or anything. infact its common to remove them on cars that came with them factory.
