Old 06-09-2007, 11:47 AM   #1 (permalink)
wes
712 ways to be a dick!
wes's Avatar
Trader Rating: 27 (100%)
Update on my sh*tbox....
Well the turbo GA has been running great. Thing just flat out rips at 11PSI and above, powerband is perfect and so totally usable on a roadcourse. My original plans were to try and make more power with the car but with the way it sits that is not necessary! I realized this after doing the track day at this years SERCA convention. After giving several SR20 owners (turbo, vvl, etc...) rides I realized the power is so well balanced I do not want to mess with it. And this is just at 11PSI when I normally run 14-16 PSI regularly.....
I have decided to fully sort the car suspension, brake, and aero wise. My first step was to upgrade the suspension. I posted the details of this in the Koni thread, but many people have not seen it thus I thought I would re-post for people to check out.
Here is a decently thorough write-up of the shortened Koni setup I built for my car. I could not have done this without the help of Steve Foltz, Lee at Koni, and Jon at O2 induction.
I chose the B15 Inserts and off the shelf rears for my project. I plan on starting with 350/300 spring rates and possibly going up from there. I will not run more than 450 though so that is why I chose the Spec V inserts. I also wanted to be able to use my OEM housings as well. I also chose to use the Koni sleeves and perches rather than thr fround control. I think they are better quality and actually are a smaller outer diameter which is nice.
Here is the donor housing looking a little worse for wear.
I drilled a small hole in the bottom to drain the fluid and then enlarged it with a step bit.
Next I measured and cut the end of the housing to remove the OEM strut rod assembly.
Nest I cut off the stock spring perch assembly and then ground off the welds.
Next up was a trip to O2 induction for some machine and welding work.
We machined the top of the Koni insert so that the KOni sleeve would be able to slide over. We did this so we could assemble the insert in to the OEM housing and then install the sleeve afterwards. This will also allow us to remove the sleeve if we ever have too.
We also took the rear spring perches that Koni provides and machined them down to use as perches for the Koni coilover sleeves. They are step machined to match the OD of the Koni sleeve and also match the inner step of the Koni sleeve.
Here we fit the sleeves for welding, the tape was used to hold the sleeve in place to level the perch for finish welding.
Welded Perch
Machined step for coilover sleeve.
Here is how the sleeve will fit once it is finally assembeled.
Next the housngs were powder coated flat black and paired with the inserts and necessary install parts.
Next I cut 12mm off the end of the insert.
Insert prepped with JB weld.
Insert fully seated.
Here is a closeup of the proper parts needed to finish the bottom off. Star washer, fender washer, and bolt provided by Koni. The black ring is a 1" x 5MM thick headset spacer I bought at a bike shop. I followed Steve's advice on this and it worked perfectly!
Assembly duct taped and ready for the install of the Koni sleeves.
Sleeves siliconed in place and ready for perches and springs.
Here is what we did with the rears. Again B15 Spec V rears with Koni sleeves and perches.
Here you can see the circlip on the rear that the Koni sleeves is designed to rest on.
The Koni sleeves are too long for the position of the circlip on the B14/15 rear setup.
We cut the sleeves down on the band saw.
Next we used some silicone to hold the sleeves in place.
Rears completely assembeled.
my site
Old 06-09-2007, 11:59 AM   #2 (permalink)
wes
wes's Avatar
After installing the suspension I had the car aligned properly and took it to the SERCA track day. My impressions are that the Koni setups are the best available! The car is so absolutely neutral, after years of living with the old GC AGX setup I am amazed at the difference.
I will continue to get the suspension dialed in, I plan on raising the car a little. I am also going to add the whiteline caster bushings and upgrade the stock front swaybar to a progress. From there I am going to upgrade the front brakes and then I will start to work on aero and air management through the engine bay. I will be sure and post pics. as I make progress.
Here is a pic. of the car on the new suspension.
Old 06-09-2007, 12:13 PM   #3 (permalink)
<>< Jesus is the Answer
blairellis's Avatar
Looks good Wes! I like how it sits with those.
BTW, I like the chrome Nike swoosh on the side of your car
Blair
93 P10
Old 06-09-2007, 12:28 PM   #4 (permalink)
t-top whore
good job wes, nice to know things are going well if your ga16!
oliverr87 is offline   Reply With Quote
Old 06-09-2007, 12:43 PM   #5 (permalink)
200 whp club
Wes FTW
Damien
B15 SE
B13 SE-R
dmp316 is offline   Reply With Quote
Old 06-09-2007, 01:08 PM   #6 (permalink)
Fun Hater
Nice job that is some top notch s**t.
91'SE-R
NO WAR FOR HEAVY METAL!!
grinch77 is offline   Reply With Quote
Old 06-09-2007, 08:11 PM   #7 (permalink)
korean domestic market
Sexy assssss sh*tttttttttt
Eric Kim l 1991 Sentra SE-R l UCLA
Canon EOS 350D l Canon EF-S 18-55mm f/3.5-5.6 l Canon EF 50mm f/1.8 II l Sigma DC 18-200mm f/3.5-6.3
http://www.erickimphotography.com
ekizz is offline   Reply With Quote
Old 06-09-2007, 08:17 PM   #8 (permalink)
Beware....THE BEAR!!
budsang1's Avatar
Trader Rating: 36 (100%)
is sexy ass sh*t supposed to be flattering
Looks good man!!
budsang1 is offline   Reply With Quote
Old 06-09-2007, 08:26 PM   #9 (permalink)
Peggy the Eggy
i can think of a few words that would better describe your car than sh*tbox
burton
We are a community
burtoNX2000 is offline   Reply With Quote
Old 06-09-2007, 09:51 PM   #10 (permalink)
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
Nice writeup, Wes... what tires are in the picture above?
Old 06-09-2007, 11:50 PM   #11 (permalink)
wes
wes's Avatar
225 50 16 Hankook Z211's. They are 9 " wide
Old 06-10-2007, 12:26 AM   #12 (permalink)
Hostile Aberration
Shawn B's Avatar
Beautiful work, brilliant suspension choices, killer pics and write-up.
Old 06-10-2007, 09:09 PM   #13 (permalink)
working on it
swiss's Avatar
Trader Rating: 23 (100%)
That car is flat out raw. Great work Wes, it was nice seeing it in person.
Old 06-10-2007, 09:23 PM   #14 (permalink)
wes
wes's Avatar
Thanks Swiss, that means a lot!
Old 06-10-2007, 09:32 PM   #15 (permalink)
YOUR F0RUM SUX
Sweet ass stuff man.
So in basic time how many hour's did it take you to complete this setup? I can't wait to make it up there now! I so **** go for a dip in that boost pool.
Sentrixx is offline   Reply With Quote
Old 06-10-2007, 10:21 PM   #16 (permalink)
slave to the grind
TOOQIKK's Avatar
Trader Rating: 28 (100%)
have watched this car evolve over the years and am always amazed at what you come up with wes! great job again!
1991 xe....dead(boneyard)
1994 e.....dead(parted out)
2007 hyundai accent DD for now
1987 pulsar se AWD-T
www.lubedealer.com/dkinney
for all your amsoil synthetic oils and filters
also sell ngk , mother, wix, and other products!
Old 06-11-2007, 08:54 AM   #17 (permalink)
awesome job wes
Later, Jay
09 scion xb - dd
92 sentra SE-R - yellow, gti-r powered - under construction
jingjing is offline   Reply With Quote
Old 06-11-2007, 09:50 AM   #18 (permalink)
Canyon_Boogie
Trader Rating: 57 (100%)
make me a set
Be polite, be professional, have a plan to kill everyone you meet.
~KnuckleDuster~ is offline   Reply With Quote
Old 06-11-2007, 12:51 PM   #19 (permalink)
What size wheel&tires do you have and NICE setup on the GA!!!!!!!!!!!!!!!!!!!!!
srpowrd is offline   Reply With Quote
Old 06-11-2007, 01:10 PM   #20 (permalink)
McCoy's Avatar
From earlier in the thread...
