Originally Posted by macidcrook
i thought the gc are to soft but with the sways it made it much stiffer where i like it. i still think its soft so im going to put some stiffer eibachs on but not for a little bit. im going to wait to see how it feels fully stripped. a figure a few hundred pounds lighter might make it right where i want it.
See if you can get the springs in a 325F/275R spring rate - sh*t even go stiffer. I think mine is alright but i feel you.
When you strip it make sure you adjust your height... the front will weight a bit more without interior/trunk/webbing/whatever. My car's rear would lift a bit over very small bumps and discrepencies in the road, so I lowered the rear a bit to transverse a little load.
I need to put those bars on.
