Old 07-22-2002, 12:25 AM   #1 (permalink)
The Groove Master
Rittmeister's Avatar
Whatcha think?
I'll eventually get a power-telescoping antenna, but in the meantime:
There's an inline amplifier I'm still trying to decide where to tap power from, but reception of local radio stations seems unimpaired. Hey, it was nine bucks.
1990 240SR - the DET has landed.
Kent's Funkay Disco
Old 07-22-2002, 01:30 AM   #2 (permalink)
Z28=mullett
thats awesome, man. whered you get it? I have the factory antenna from a Focus ZX3 on mine right now, which looks good, but it leans over at about 45* when I go over 60
-Parker
'92 SC300-5 speed, stock and plush
'95 G20- 5spd,bone stock beater/daily driver RIP 10/03
'99 Camaro Z28-F1 cammed, Long Tubed, and True Dualed sold
'91 SE-R-14.7@91-SOLD
playatx99 is offline   Reply With Quote
Old 07-22-2002, 02:25 AM   #3 (permalink)
llaprad1's Avatar
Hmmm. Must've been cold outside.
llaprad1 is offline   Reply With Quote
Old 07-22-2002, 03:15 AM   #4 (permalink)
Very bling bling
you need one that pivots...
like mines does.
jr
http://www.angelfire.com/empire/se-r/
http://img9.imageshack.us/img9/4582/jorge11.jpg RIP:1991 B13 a.k.a. Darkness with gen5 HS , CAI, S4's, UR pulleys, courtesy b-pipe, fid_flywheel,ACT extremePP and 6 puck madness. 296,009 miles and no longer rolling. now P10 turbo powered. www.myspace.com/jorgejason77
SuperblkStalion is offline   Reply With Quote
Old 07-22-2002, 11:37 AM   #5 (permalink)
Nice and stubby :p
I totally took mine out, and used one of those antenna strips.
PS 1700th post
Old 07-22-2002, 07:48 PM   #6 (permalink)
The Groove Master
I got it at Meijer. It was the last one, I don't know if you can get them elsewhere, but it was a gin-u-wine Rally part. It has an inline amplifier, any thoughts on where to tap power for it?
Serban, how'd the window-stick antenna work, as far as installation and reception? I've been thinking about that possibility as well.
Old 07-22-2002, 10:34 PM   #7 (permalink)
Z28=mullett
for power the easiest thing is to tap into the switched and constant leads going into the headunit
Old 07-22-2002, 10:59 PM   #8 (permalink)
The Groove Master
The real trouble is how to get the power wire from inside the fender into the interior. I can't get it through the hole where the antenna wire goes, but I haven't looked closely to see if there's a rubber washer there I could pop.
Which wires are the "switched and constant leads going into the headunit?" There's only one wire on the amplifier, the directions say to hook it to 12V power. They even provided the scotchlock connector
Old 07-22-2002, 11:24 PM   #9 (permalink)
Z28=mullett
well. depending on the current draw of the signal amplifier, it may be best to use a relay... if you were to wire it to the constant power wire(yellow if you have an aftermarket wiring harness adapter for your HU) it would always be on, and it would be possible for the battery to be drained if left on for a long time. on the other hand, I doubt that the current draw would be too much for the switched 12v circut(the red wire on the HU harness).... i would just try that, run a wire through the closest hole you can find in the firewall(theyre all over the place) to the 12v spot on the amplifier and the other end to the red wire on your HU harness, that should do it.
Old 07-22-2002, 11:30 PM   #10 (permalink)
The Groove Master
Thanks bro.
Old 07-23-2002, 11:39 AM   #11 (permalink)
And the wierd turn pro.
Why not use a relay and use the power antenna lead from the head unit to trigger it? That way the amp is only on when the you're using the radio.
That antenna looks awesome. It's definitely going on my "to do" list. I just got my classic, and immediately the antenna was the only thing I wanted to change cosmetically.
Ben
92 SE-R
66k miles and stock. . . for now
frkpwr is offline   Reply With Quote
Old 07-23-2002, 06:33 PM   #12 (permalink)
The Groove Master
I don't know where to get a relay or how to wire it. ALL of my electrical expertise has to do with house wiring type stuff; I have no experience with low-voltage systems. Any suggestions?
Old 07-24-2002, 05:52 AM   #13 (permalink)
<>< Jesus is the Answer
blairellis's Avatar
thats phat! i might just go buy one for the hell of it...its only 9 bucks
Blair
93 P10
blairellis is online now   Reply With Quote
Old 08-12-2002, 01:18 PM   #14 (permalink)
needs to be tuned
geeio's Avatar
i want one
where can i get it who makes is can i get an other one online or can i get one smoe where else i need a new antenna mine is crap
looks like its got a bad sun burn.
geeio is offline   Reply With Quote
Old 08-17-2002, 09:20 AM   #15 (permalink)
Back in action 2/28
Yup. It does look like it heheh
Turbo 1995 200sx SE-R
especse_r is offline   Reply With Quote
Old 08-18-2002, 03:16 AM   #16 (permalink)
blairellis's Avatar
well ive looked 3 times at meijers and cant find em. Anyone wanna pic me up one? If so PM me.
Old 08-19-2002, 06:05 PM   #17 (permalink)
JordanWhiteMusic.com
That car reminds me of Chuck Cragnolin's car from NY.
Jordan - '94 Sentra LE
'07 Honda Fit Sport
www.myspace.com/jordanwhite
Storm88000 is offline   Reply With Quote
