That was just an idea. I really like the location (plus its original). I will have to get an electrical boost guage; its too tight to get a vacuum line up through the steering column (may be able to use that crap nylon tubing, but I don't want to).
I used a hole saw to cut through the rubber coating and there is a 1/8" thick plastic piece next, and then about the same thickness aluminum frame under that. After some dremel work the guage squeezes in there and is held in place by friction although I plan on using the plastic sleeve that screws to the back provided by VDO. As long as I can devise a way to get the boost signal wire to the guage and have a reliable connection to the guage (that won't break when turning the wheel) I will have a nice custom set-up.
I was actually toying with installing a bearing in there, but I could only find a select few that
may fit but they weighed a couple pounds and were probably to bulky to fit in such a small space.
If I can get everything to work I will definitely post a how-to in the turbo section.
Thanks for the comments
