Sorry I didn't get a chance to call you back. Things have been busy with a new job and trying to get my Sentra ready for inspection.
Yeah, you never want to call back
Anyway I promise you this time I'll be doing the dirty work and you can do alot more watching
Still having trouble with your inspections huh......I am guessing because of the cams?? Why not just swap them out? I'll help you do it, should only take us a hour to do?? Its up to you.
Old set-up: 91 se-r sr20de+T 13.04@110mph w/ a t25 and s3's!
New set-up: 91 se-r gti-r sr20det w/ a gt28r, msd 72lb inj., N62 maf., Aps bov, Calum ecu, Hallman pro rx mbc, greddy tt, B&M ss, Greddy FMIC, Autometer phantom gauges, AGX's on Road magnets, etc.....
I have bad phone etiquette!
The car only has 2,000 miles on it since the last inspection (In 07), so I should be exempt from emissions testing. I just need to find a place that will overlook some things on the inspection side. It's nothing that is a safety issue.
When are you doing the swap?
Just go to one of those old school mechanics and you'll bee fine.
so when is this going on ?
the gti-r swap is basiclly the same as all the other det's only you have to swap 2 tps wires and ad resisters for the low impednce injectors.
wish yah luck.
Yo, mike this is john the guy who called you a couple weeks ago and asked you some gtir swap questions and you seemed busy and told me to call you later at night.......anyway if you have some spare time and would like to come over for the swap your more then welcomed if not no problem
My address is
252 gramercy drive
clifton heights PA 19018
phone# 610-999-1553
john
btw I would also love to see and go for a ride in your p10!
I do not think i can make it. i had blowen 3rd gear in my p10s trans and have recently took it a part to get al lthhird gear peaces out so the trans lasts till i have the parts for my new one.
i also have to help my sisters boy friend do his sr swap in his s13
Thats a shame mike it would be nice to have you there, but as long as T and chris come things should be fine
T and chris please chime in and confirm your coming please.....
Ok, cool....The only thing I have to do is find a flywheel or just put the motor in without the tranny???, because I don't have a drill press to open up the holes. Any idea's?? And I also have to cut the fins off the upper oil pan, which I am assuming we could do when the motor's up on the engine hoist??
I have a update about the flywheel. My neighbor is going to take the flywheel while we are playing with the car and open the holes up(should only take him 10-15 minutes, so we'll be able to complete the install! The only problem now is my ecu? I need new chips from calum.....hopefully I can get a hold of him this week, so he can send the new chips out. I will also need a radiator, but my stock will do for now....
its only 2 hrs away..ill also see if Theo and Alex can roll..Their knowledge x2 mines
T at the end of the direction's instead of going straight down baltimore pike you have to turn left onto s. bishop, then right onto n. springfield, then turn left where you see westbrook park elementry then left onto gramercy dr. 252 is my address.
