FS: JWT Ecu for 96 g20t s4 program AT tranny and lots of other p10 stuff SUper Cheap!
i need this gone, it's programmed for the rev limiter higher, governor removed, s4 cams, cold air intake bored MAF, exhaust and a few others, asking $400, or will take the first reasonable offer
Here are some stuff i need to get rid of. name your prices.
I'm in the market for an A/T jwt ecu.. but I don't have half the mods that its programmed for... any chance you can reprogram it? Or do you think it would work on this setup:
^^^ seeing as how JWT typically only setup their ecu to compression ratio, injector size, and the MAF, you should be ok if you get the bored maf from him too. If not a retune would be in order.
