ALL MOTOR (NA) SR20DE Performance Built Engine - SR20 Forum
Go Back   SR20 Forum > Classifieds > Naturally Aspirated Performance Parts
Old 09-12-2011, 01:41 PM   #1 (permalink)
easy 400WHP
Feedback Score: 36 reviews
Fully assembled SR20DE Longblock Engine
Considering $$$$ SERIOUS OFFERS ONLY$$$
Located in Southern California
Willing to ship anywhere in the world, US, delivery or pick-up within SoCal/Las Vegas areas available.
I prefer Check, Money Order. Willing to take PayPal + fees.
Any questions or inquiries can be directed to at3joserodnx AT hotmail DOT com or 760-7-92-020-4 for faster service
Description:
some specifics:
DET head w/ sodium filled exh valves and mild port/debur job
C3 Cams
JWT springs and Ti Retainers
98 rocker arms
all slotted pucks (no flat shims)
RR HVLA's
CS Cam Gears
ARP Head Studs
OEM Nissan HG
Fully machined, cleaned and prepped DE Block to GTiR specs
360 degree main oiling
internally polished crank case and oil passages for oil shedding/windage reduction
All new Stainless Steel Freeze plugs
OEM VE oil pump kit
VE 4CW crank (Knife-edged, chamfer and polished)
Custom Crank Scraper
modified upper oil pan for windage reduction
Eagle Rods
SR16 Pistons
Custom Piston Oil Squirters (improved oil flow and positioning)
Calico coated ACL main, rod and thrust bearings
full OEM Nissan Gasket set used for assembly (all new seals/o-rings/gaskets)
Motul Assembly Lube
Permatex RTV for sealant
The majority of the heavy machine work was done by Rebello Racing in NorCal
The crankshaft knife edging and work up was done by Castillo Crankshaft Services in SoCal
Prep, Measurement and Assembly was performed by me.
I will include as many stock parts as I have available to assist your assembly/install at no cost
Any goodies I have laying around that will go good with this engine will also be included...JDM intake runners, Intake ThermoGasket, Stainless Steel Hardware, Copper Self Locking Header nuts, etc etc...
Images:
So thats about it...I may be forgetting some stuff...but the point of this thing is the attention to detail/prep/machine work and the windage and crank case improvements coupled with a solid valvetrain/cam setup and the higher compression of the proven sr16 pistons in a DE. I did a leakdown test on all 4 cylinders and passed w flying colors. One of the best Ive personally seen even on a new engine...
I expect with good injector choice, tune, light flywheel and manifold configuration it would easily make reliable power approaching slightly under the mid 200's with a nice well distributed and somewhat controllable curve (as opposed to a VE) and can be reved pretty well without having to go to hell and back to make the necessary power.
It was intended for a track car I was building where I didnt want to have to rev super high to make power to get out of turns, elevation changes, etc.
The build cost me a little over $4,000 and that was with using some of my own parts off my shelf, several discounts and hookups from people I know. I have an Excel Spreadsheet documenting all of the parts/machining costs. I also have alot more detailed photos of some trick machine work done that I will only reveal to the buyer.
Any SERIOUS BUYERS please feel free to make me an offer.
Shipping can be arranged to ANYWHERE US or International. I am willing to go 50/50 on shipping and wil use a very reputable Freight company.
Please feel free to ask me any questions you may have if you are looking to purchase.
Please no tire kickers and please no advice or how/why did you do that type of questions.... There is a discussion thread in the All-Motor section if you just want to chat and I will be happy to discuss there
Hate to sell, but have no choice. Hope someone can give it a good home
~jRod
Old 10-06-2011, 10:44 PM   #2 (permalink)
easy 400WHP
bump....
Old 10-29-2011, 03:42 AM   #3 (permalink)
hi, how much will you accept for the engine? i don't know much offer.
how many horser of power are we talking about?
sr20ve lover!
evencio is offline   Reply With Quote
Old 10-31-2011, 01:19 AM   #4 (permalink)
easy 400WHP
horsepower will depend on what you bolt on to it such as intake and exhaust manifolds, ecu/tuning, injectors, etc. I would estimate it would have no problem making over 200 whp with a good configuration. I cannot predict an exact number I can guess 210, 220, etc but that will all depend on how you finish the build.
The engine cost me a little over $4000 just to prepare and build. An offer in the Mid 3000's would be nice.
Old 11-17-2011, 03:25 PM   #5 (permalink)
SE-R enthusiast
Feedback Score: 12 reviews
Same head, porting, cams, springs, pistons, crank scraper & windage tray, oil squirters, etc. Other than the modified crank and I WPC treated everything, my race motor is exactly the same . Well over $4000 is what mine cost to build as well. Car just came back from getting full cage installed. My engine will be matched to a JDM ported intake manifold, Hotshot gen VI 3" dump exhaust, 8lbs flywheel, 370 cc injectors @4Bar and B15 trans. I expect 200+ and will be willing to share my tune in JAN when I dial in my Calum Realtime.
1993 Red SE-R racecar: getting ready for TTD
2005 Mitsubishi Evo- E85/30psi stock turbo
450tq/443 hp
viscos2000 is offline   Reply With Quote
Old 11-17-2011, 03:33 PM   #6 (permalink)
SE-R enthusiast
Someone buy this motor and save a buttload of money and time that can be used for racing. If I didn't build in parallel, I would totally capitalize on this deal. Very professionally and reliably done.
Old 11-24-2011, 02:03 PM   #7 (permalink)
easy 400WHP
Thanks Chris!! Good luck with yours!! Keep in touch and let me know how it turns out. I dont come on here as much anymore these days, but Ill try to keep my eyes peeled.
As far as everything else, Pretty much the same set up I would go after as far as flywheel/fuel/Manifolds/ecu. I hope to see you make it into the 220 range.
Best wishes man. I remember when we first discussed building these motors a couple years back LOL
Old 12-19-2011, 02:13 PM   #8 (permalink)
easy 400WHP
xmas bump
Old 12-22-2011, 12:36 PM   #9 (permalink)
SE-R enthusiast
Engine going in next week-Holiday break- YAY!
Old 12-22-2011, 05:14 PM   #10 (permalink)
easy 400WHP
nice!!! best of luck man!
Old 12-22-2011, 09:06 PM   #11 (permalink)
Im not trying to be a dink I have a question, in one of the first few pic the crank is laying down, how long was it laying down for?
92nx2ksr is offline   Reply With Quote
Old 12-27-2011, 04:41 PM   #12 (permalink)
easy 400WHP
it was laying down just for the picture prior to assembly. Maybe a total of 30 minutes. The rest of the time it was wrapped in bubble wrap and sitting in a nicely cushioned box.
Its not bent if thats what youre getting at LOL
Old 01-10-2012, 08:13 PM   #13 (permalink)
easy 400WHP
2012 bump!!!!
Willing to make a smoking deal for a serious buyer!!!!!
Show me the Money!!!!
Old 01-30-2012, 02:01 PM   #14 (permalink)
easy 400WHP
still for sale.....make me an offer!
Old 02-02-2012, 03:27 AM   #15 (permalink)
SE-R Turbo Slut
Man the juices are starting to flow Jose...lol
I will be in LV Feb 16-25 hitting the LVR on my Ducati. We should hook up.
Larry Low
http://s294.photobucket.com/albums/mm106/low612/
LAMO IMPORTS
k6 GSXR 750
08 Ducati 1098s Black
1999 sentra se-l
1992 Pulsar Gti-r
Low612 is offline   Reply With Quote
Old 02-09-2012, 02:11 PM   #16 (permalink)
easy 400WHP
For sure man! Hit me up.
Old 02-23-2012, 01:23 PM   #17 (permalink)
easy 400WHP
bump for the sale of this engine....needs to go!!!
make me an offer!!!
