Go Back   SR20 Forum > What's New > Technical Information Library > NeoVVL Guides
Old 02-13-2005, 03:29 PM   #1 (permalink)
70/30 Racing
Rockwood's Avatar
HOW TO: Configure GReddy MSS
Hold down "MODE" to go to between the setup screens. Hold down "select" to adjust brightness. Make certain to push in the rotary knob every time you change something or it wont save it. To set the RPM at which it engages, hold down "MODE" until it goes to a screen where it has an RPM readout (probably 0), then hit "MODE" once. This will go to solenoid 1 setup. Push the rotary button to change the values, push the "select" button to go between parameters (RPM, voltage, temp, boost, etc). Push "MODE" again to go to solenoid 2 setup.
The base settings should read as follows (hold "MODE" to access):
Top=little dash on top
Bottom=little dash on bottom
Pr - Top
C4 - Top
P2 - Top
When the 1 is shown, it says "ON"
When the 2 is shown, it says "ON"
In the actual parameter setup, I have (stock SR20VE cams):
1 (exhaust):
On 4800
Off 4790
Everything else is ZERO unless you set it for TPS or temp (only engages when warm).
2 (intake):
On 4600
Off 4590
***EDIT***
I used the yellow/red wire right off the ECU (4th one from the bolt, not right next to it) for the RPM signal. The green/yellow wire on the coil creates issues and will occasionally read "0". This was on my OBDI P10, which should be the same as a B13.
Steve Rockwood
2004 Ram 2500 - 600lb-ft of towing powah!
92 G20 - PTD #73
Old 02-13-2005, 03:50 PM   #2 (permalink)
Neo'ed
Have you got the inlet cam on number 2? Most people Ive seen bring that on 1st
Old 02-13-2005, 04:53 PM   #3 (permalink)
70/30 Racing
Rockwood's Avatar
yeah, intake is on #2. doesnt really matter, as long as you know...
i will edit that.
Steve Rockwood
92 G20 - PTD #73
Old 02-14-2005, 01:42 PM   #4 (permalink)
Trader Rating: 17 (100%)
Steve --
Will these specs activate the audible alarm at specified RPM also (assuming that you set the alarm)? I'm getting the red display, but no sound. Is there a volume setting or something?
Thanks much,
Bill
Old 02-16-2005, 12:13 AM   #5 (permalink)
70/30 Racing
Rockwood's Avatar
i didnt set the alarm tone. i am sure you can, i just dont know how.
these settings will at least get it working...
Steve Rockwood
92 G20 - PTD #73
Old 02-16-2005, 09:34 AM   #6 (permalink)
Right you are...
and thanks for providing them.
Bill
Old 03-21-2005, 05:58 PM   #7 (permalink)
70/30 Racing
Rockwood's Avatar
added which wire to use for RPM signal.
Steve Rockwood
92 G20 - PTD #73
Old 03-21-2005, 07:15 PM   #8 (permalink)
FWIW, the y/r wire (Pin #3) did not work for me in my 1993 SE-R. The one next to it -- blue with black stripe, (Pin #2) did work for me.
Old 03-21-2005, 08:39 PM   #9 (permalink)
70/30 Racing
Rockwood's Avatar
is the y/r wire pin #3? there are 2 y/r wires, and i picked the one that is 4 pins away from the bolt, not right next to it. that wire is just a power source for another component. did you use the one that is 4 pins away?
Steve Rockwood
92 G20 - PTD #73
Old 03-22-2005, 08:29 AM   #10 (permalink)
Steve --
I used the y/r wire that you pointed out -- it's Pin #3, 4 wires from the bolt toward the driver's side, top row. Pin #2, the one that worked for me, is the 5th wire, right next to the one that you used, and it's blue with a black stripe.
When I was hooked to Pin #3, I got a signal that the MSS read as RPM. It was right most of the time, but jumped around a lot. I tapped into the wire a second time and got the same results, so I don't think it was an execution problem. Paul's site (Pachadwick) also reported that Pin #2 worked for him. In the B13, Pin #2 is the wire that goes to the tach from the ECU (through a couple of connectors).
Don't know what else to say, except that the car is still pulling all the way to red line. Except, again, that I appreciate all the help that you and other Forum members have given on this and other problems. I never would have even considered this project without the support of the Forum.
Bill Conner
Old 03-22-2005, 04:10 PM   #11 (permalink)
70/30 Racing
Rockwood's Avatar
hmm...
oh well.
so either will work i guess, though yours seems to be more reliable in your case. mine doesnt jump around, but it does read slightly low (ground loop noise). it never reads "0" except for a second or two after i start it.
Steve Rockwood
92 G20 - PTD #73
Old 03-22-2005, 06:53 PM   #12 (permalink)
FWIW, my tach reads lower than the digital readout on the MSS. It's off about 200 RPM at 7400 RPM indicated on the tach. So I can rev by my tach to 7400 RPM even though the ECU is set to cut fuel at 7200. I chalk this up to tach error.
Bill
Old 10-21-2005, 08:25 PM   #13 (permalink)
having problems guys
installed my mss on my sr16ve having trouble with rpm signal and mile per hour reading it seems wrong
need help urgently
8870ssgti is offline   Reply With Quote
Old 10-29-2005, 01:33 PM   #14 (permalink)
I have my solenoids connected directly to the battery and the MSS turns off just fine for me.
Old 10-30-2005, 10:05 AM   #15 (permalink)
Same here -- no problems for me either. Could the problem that Ninety-Nine SE-L is having be related to the wiring of the orange and red wires? One is supposed to be switched and the other not -- but some folks, I believe, have wired them both the same way -- thinking that it doesn't matter. Just a random thought.
Bill
Old 10-30-2005, 10:15 AM   #16 (permalink)
so does anyone know how to stop the beeping?
The alarm is triggered by RPMs. You probably have it set so low that it beeps all the time, along with the red display.
One of the RPM settings is "Alarm." I can't remember exactly how to get to that point in the programming, sorry. But you should be able to find it if you spend some time looking for it.
Old 10-30-2005, 10:37 AM   #17 (permalink)
Originally Posted by billc
Same here -- no problems for me either. Could the problem that Ninety-Nine SE-L is having be related to the wiring of the orange and red wires? One is supposed to be switched and the other not -- but some folks, I believe, have wired them both the same way -- thinking that it doesn't matter. Just random thought.
Bill
Thats what it sounds like to me (having never touched one). One is the primary power the other is a switched power. The switched one causes the thing to turn on and off. Just like a radio. Of course you can avoid the entire issue by only giving the unit switched power. As long as it does not loose the settings when it looses power then it really should not matter.
Steve
06 G35 6MT
Old 10-30-2005, 09:06 PM   #18 (permalink)
yea, I know how to actually stop the alarm from going off, I want it to still turn red, but I want to turn down the volume.
Sorry, I was never able to figure out how to control the volume.
Old 11-25-2005, 03:45 PM   #19 (permalink)
2 questions
How do i reset the mss?
How do i know the cams are switch on ? .. is there an indicator on the mss???
mr.vvl is offline   Reply With Quote
Old 11-26-2005, 07:36 AM   #20 (permalink)
AFAIK, there is no way to reset the MSS per se. You have to change the settings that you want to change. See Post #20 in this thread http://www.sr20forum.com/showthread....&highlight=MSS
for a more detailed run through on how to program the MSS.
Good Luck -- it's worth it once you get the MSS working.
Bill
HTML code is On
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
