How I swapped my VE into my '93 SE-R - Page 2 - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > NeoVVL Guides
Old 11-05-2006, 06:30 PM   #21 (permalink)
Luke Pighetti
Taiden's Avatar
Feedback Score: 3 reviews
Originally Posted by p10det
Im just gathering a bit of knowlaged the best i can right now. I am wnting to get a good ve swap done eventually. I have done quite a few det's and such but i am really interested just in case a freind wants a VE done or i decide to do one in a future car. I was farely sure the VE maf would not work on b13 ecm but figured it might.
if i do one i think that jwt can give me a good program for the maf injector cc and compresion thn i geuss it is up to me to wire and triger solinoids at a desired rpm?
yes!
Old 11-06-2006, 06:51 AM   #22 (permalink)
thank you.
p10det is offline   Reply With Quote
Old 11-17-2006, 07:57 PM   #23 (permalink)
Is an SE-R/VE a VE-R?
Rob, I'm REALLY glad you had the patience to document this. I was all taken up with going out in the cold on the carport over the winter to inch along a few hours a night once or twice a week, it was just less than fun sometimes.
For an alternative for the 8969 location, take a look where I put mine:
http://photo.angrylabs.com/main.php?g2_itemId=118
and if you want to see how I did some of the other stuff, back up into the website to look around, I've got several pics there. I REALLY recommend conduit for your new wiring, you'll see that EVERYTHING - even the throttle cable and the Apexi valve cable - are in it. Cheap for a 50' roll from NAPA, even if you don't do forty miles of wiring like I did (four gauges) it'll still be cheaper than buying those worthless 5' pieces at Advance or wherever. And if you don't add gauges you can give/sell half of it to the next guy who does this.
Taiden, you runnin' yet, bud?
'93 B13, etc.
do it over and over again?
Old 07-24-2007, 08:43 PM   #24 (permalink)
Feedback Score: 11 reviews
New post to an old thread. Im not doing my VE swap into a b13 and snapped some pictures of some things necessary to the swap.
Temp sensor swap:
Distributor modification:
Ignitor Chip (or w/e it is called):
IACV/AACV (yet again or w/e its called):
VVL Solenoids (i think these are the correct wires to splice to the msd):
MSD8969:
DE SSAC exhaust mani on VE:
So far thats where im at with the swap over, hopefully some major progress tomorrow.
My car is old.
SR20 Soon? is offline   Reply With Quote
Old 07-24-2007, 10:25 PM   #25 (permalink)
1.6 3/25/06 VE 7/11/06
Feedback Score: 25 reviews
my ve never had a ignitor chip
bj200sx is offline   Reply With Quote
Old 07-24-2007, 11:47 PM   #26 (permalink)
Thats because you swapped it into a b14, a b13 has an obd1 system and an older electrical system using an ignition coil seperate from the distributor also using an ignitor chip or w/e its called. For a ve into a b13 swap unless do a ton of electrical work, it is required.
Old 04-01-2011, 12:18 AM   #27 (permalink)
The VE install is not that hard. Other than a few things, it's the same as putting a DE in.[/QUOTE]
ca you use the tranny from a de on a ve?
96_se-r is offline   Reply With Quote
Old 03-02-2012, 09:40 PM   #28 (permalink)
Thanks to all 4 the info and pixs is going to help me a lot with my swap. one question do i use my stoke ecm? and i hab a 93 ser.
CHILLO is offline   Reply With Quote
HTML code is On
