greddy mss translated wire diagram - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > NeoVVL Guides
Old 03-25-2007, 10:16 AM   #1 (permalink)
AKA-- JJKAMIKAZE
Feedback Score: 8 reviews
I know this can be found on a few sites, but i don't trust other people so I translated it myself and drew a quick MS paint diagram. I'm fluent in Japanese and my wife is native Japanese(i actually needed her help for some of the manual) so i assure the accuracy. I just thought it was weird I couldn't find it on here and had to link to other sites to find it.
image shack stuff disappears after a while so maybe a mod can host it differently.
NismoTheDog is offline   Reply With Quote
Old 04-19-2007, 01:18 AM   #2 (permalink)
Feedback Score: 26 reviews
whats the "speed" wire????
92 B13 ser:Black sr20VE
95 4Runner:Black
79 Ford f-150: Brown-wheelin machine
stephenjk13 is offline   Reply With Quote
Old 12-19-2007, 10:04 AM   #3 (permalink)
Good day,
Do you know if the wiring for the solenoids are replaced or tapped into the stock one's? If it is tapped into what would be the effect on the ECU when the MSS activates.
Also currently I ran a manual switch for testing purposes and a realize that a knock develops from the engine. This also happened when I unplugged the solenoids prior to connecting the switch after I plugged it back the knock was gone.
Thanks much
Shazman is offline   Reply With Quote
Old 12-24-2007, 10:19 AM   #4 (permalink)
Good day again,
Just in case anyone is wondering. I hooked up the Greddy MSS no probs. Thanks to Dry for advice.
Shazman
Old 01-20-2008, 02:32 PM   #5 (permalink)
vz-r driver
some how this diagram doesnt look accurate.....
THOR is offline   Reply With Quote
Old 01-20-2008, 05:32 PM   #6 (permalink)
Feedback Score: 9 reviews
Thanks for the information.
MegaSoreAss is offline   Reply With Quote
Old 07-03-2009, 04:58 PM   #7 (permalink)
THANKS I DID NOT KNOW HOW TO INSTALL THE MSS
NISSAN B13 NEO VVL
nucocolisoz3 is offline   Reply With Quote
Old 12-30-2009, 02:02 AM   #8 (permalink)
can a kit like this be used on a tps?? or do i have to convert to manual to play with shift points
B14sentraDriver is offline   Reply With Quote
Old 05-16-2010, 03:13 PM   #9 (permalink)
AKA-- JJKAMIKAZE
you can wire it to work off throttle, speed, temp, rpm. it takes a little playing with but you can make it work off just about anything on the motor that outputs a range of voltage. i have now had my mss hooked up since before i first made this post and it has worked perfectly for me everyday since. its a great little device.
HTML code is On
