SR20VE Installation FAQ - Page 4 - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > NeoVVL Guides
Old 09-17-2009, 04:22 AM   #61 (permalink)
Vtec?
hey guys, im planning to drop a VE then use DE harness, distributor, maf and ecu any future problems? btw ill use safc2 for a/f correction
gspec is offline   Reply With Quote
Old 09-17-2009, 08:45 AM   #62 (permalink)
Feedback Score: 17 reviews
I would strongly recommend that you use a proper VE ECU (like Calum or JWT) for engine management. This would allow you to optimize timing as well as mixture. The DE program bin file is not a good fit, even with SAFC.
The next thing to change would be the MAF -- if you are going to change the ECU you might as well go ahead and upgrade to the N60 or equivalent.
I've been running a DE MAF on my VE for years and it works fine, but I'm left wondering if there is a little gain left on the table due to flow constrictions.
Old 09-17-2009, 07:08 PM   #63 (permalink)
CR VE owner
I agree with you, JWT or Calum FTW. Now in the case of the MAF it is much better the VE MAF, in the case of the DE the internal diameter is 2.5in, in the case of the VE is 3in straight.
A friend upgraded the MAF (and he was running a DE ECU with SAFC2) and he gained like 3 whp.
It was on like 173 whp, then he installed the Calum ecu basic with the basic tune and it was on 178whp. Finally he tunned the ECU, upgraded to Sr16 camshafts and ported the head and it was hitting 194 whp last time I saw it on the dyno.
Sentra SE-R 1991 - Sr20ve. SOLD
Next project: Who knows, another VVL or EJ20G maybe, but is going to take such a long time
Toyota Van: Daily driving (so I dont have to walk )
speed demon is offline   Reply With Quote
Old 12-12-2009, 10:33 PM   #64 (permalink)
Hey uhm I wanted to swap a sr20ve into my sentra 97..The swap includes everything and 6 speed auto tranny. Also has the gauge and tiptronic sh*ter from a 98 primera. Was wondering is there any way i can change the redline on the auto? or is that impossible?
B14sentraDriver is offline   Reply With Quote
Old 12-12-2009, 11:24 PM   #65 (permalink)
CR VE owner
Well it is not impossible but to be honest it may be difficult. On VE's almost no one works the stock ECU. you could look for a rev limiter removal, which is some sort of piggy back and will allow you to trick the ECU and let it rev higher, but honestly I have seen that for Honda ECUs not Nissan.
Now what you could do is the following (kinda complicated though): Engine ECU and Tranny ECU are separate. You could buy an B13 SE-R ECU ODB1 (VE is OBD1 too) and get a calum basic chip, with that you can raise the rev limiter and get a good tune on top of that. However I dont know how the gearbox ECU will react to those changes since I imagine the tranny ECU takes in count the revs as a parameter to do the shifting
Old 12-23-2009, 01:18 AM   #66 (permalink)
ahh ok thanks..I just wanna raise it from stock 7500 to about 8200 or somewhere around that area. But ill look that up!
Old 12-23-2009, 06:54 PM   #67 (permalink)
CR VE owner
Sr20VE stock ECU cuts @7100k, I think only the SR16VE cuts at 8200 or so, and the N1 @8500, something like that, but the SR20 im sure cause I had it on my car
Old 12-23-2009, 08:20 PM   #68 (permalink)
SR22VET GODNESS!!!
DID YOU FIND WHAT YOUR LOOKING FOR?I HAVE A 94 4 DOOR WITH A VE IN IT FRESHLY INSTALLED..LET ME KNOW IF YOU STILL NEED HELP..PM ME IF YOU LIKE..IAM GOING TO DO A THRED ON HOW TO SWAMP A GA16DE TO A SR20VE.SOON IAM TYOPING AS WE SPEAK..IAM PREATY MUCH 1 OF THE FIRST TO DO IT ON A 4 DOOR AND TRUST ME ITS A PULLING SLEEPER..
SR20VET
EATHER LINE UP OR SHUT UP...
NOKTURNAL
94B13SR20VE is offline   Reply With Quote
Old 12-30-2009, 01:32 AM   #69 (permalink)
Is that an auto or a manual ur doing?? I dunno if i'm gonna have the time to do it myself though.. I have college and work..so i'm probably gonna have a shop do it
Old 01-29-2010, 12:20 AM   #70 (permalink)
sunny gts speedhead
hey guys i bought a sr20ve to put in my b13 about a month ago but i have just started the project and i found out tht the distributor doesnt work on the engine and the store doesnt want to take it back i thinks its the sr20de distributor so it cant work, does **** know where i can get a sr20ve distributor????
nismo language is offline   Reply With Quote
Old 01-29-2010, 07:50 AM   #71 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
What distributor do you have? The easiest way to go is to use the B13 distributor and cut the bottom leg off.
http://www.sr20forum.com/neovvl-guid...e-install.html
Old 04-28-2010, 12:18 AM   #72 (permalink)
Feedback Score: 5 reviews
whats going on guys i just picked up a ve engine and trying to swap it in to my
96 b14 i tried clicking the link on the first page but its not working can someone help me and let me know what i am gonna need to swap over from my stock de motor and what i am gonna need like wiring,maf,ecu? i will really appreciate it
BoostingSE-R is offline   Reply With Quote
Old 10-04-2010, 02:51 PM   #73 (permalink)
does anyone have a pic of what was done to the trans bracket when swapping a ve into a b13?
D2uning is offline   Reply With Quote
Old 10-04-2010, 03:27 PM   #74 (permalink)
VE 96 SE-R
Feedback Score: 18 reviews
it's a straight swap, you don't need to modify your DE tranny bracket. If you're having issues, have you looked at your motor mounts and clutch alignment?
Robert Sousa
SR20DEEP CA
http://i17.photobucket.com/albums/b5...IMGP5288-2.jpg
96 SE-R VE goodness
95 G20, VE super stock DD
SER96VPEC is offline   Reply With Quote
Old 11-05-2010, 10:16 AM   #75 (permalink)
if im running a ve in my 2002 g20 can i just run a ve ecu will it be plug and play?
nightryder1314 is offline   Reply With Quote
Old 11-05-2010, 11:07 AM   #76 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
No, the VE ECU can not be used. For a '02 G20, you will need to swap to a '95 - '97 B14 ECU harness and a reprogrammed ECU.
The community is here.
Old 11-28-2010, 07:31 PM   #77 (permalink)
Hey guys i have a 1997 nissan 200sx se-r.. And it has a bad valve so im goijng to do a sr20ve swap-I know i need the computer upgraded and swap the ve distributor with the b14 de one.. And im wondering if everything will bolt on and do i need to cut or get something eles..
Please help me!? -Aidan
Neo-sr20veVvL is offline   Reply With Quote
Old 11-28-2010, 09:49 PM   #78 (permalink)
VE 96 SE-R
you'll need something to switch your cams...like a GReddy MSS or MSD. An upgraded clutch wouldn't be a bad idea either.
Old 11-29-2010, 03:21 PM   #79 (permalink)
Thanks man.. But is that all i will need? Everything eles is fine?
Old 11-29-2010, 03:27 PM   #80 (permalink)
HTML code is On
