VE cam specs - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > NeoVVL Guides
Old 02-23-2004, 10:12 AM   #1 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
VE cam specs
SR20VE
Intake cam
Low lobe: 8.4mm lift @ 220 duration
Low lobe center angle: 110deg
High lobe:10.7mm lift @ 264 duration
High lobe center angle: 104deg
Exhaust cam
Low lobe: 6.6 mm lift @ 244 duration
Low lobe center angle: 122deg
High lobe:10.34 mm lift @ 268 duration
High lobe center angle: 114 deg
SR16VE
Intake cam
Low Intake Duration: 200
Low Intake Lift: 7.1
Low Intake Center Angle: 100
Low Lobe Center Angle: 111
Low Overlap: 0
High Intake Duration: 280
High Intake Lift: 11.1
High Intake Center Angle: 100
High Lobe Center Angle: 105
High Overlap: 70
Exhaust cam
Low Exhaust Duration: 244
Low Exhaust Lift: 7.95
Low Exhaust Center Angle:122
High Exhaust Duration: 280
High Exhaust Lift: 11.1
High Exhaust Center Angle:110
SR16VE N1
Intake cam
Low Intake Duration: 220
Low Intake Lift: 8.4
Low Intake Center Angle: 110
Low Lobe Center Angle: 116
Low Overlap: 0
High Intake Duration: 288
High Intake Lift: 12.0
High Intake Center Angle: 104
Exhaust cam
High Exhaust Duration: 288
High Exhaust Lift: 11.9
SR20VE (20V)
Intake cam
Low duration: 228deg
Low lift 10.10mm
Low center angle: 114deg
High duration: 278deg
High lift: 12.00 mm
High center angle: 114deg
Exhaust cam
Low duration: 244deg
Low lift: 8.30mm
Low center angle: 106deg
High duration: 280deg
High lift: 11.15mm
High center angle: 108deg
Other cam info
Timing Events:
All of the above (except lifts ofcourse) can be calculated from teh timing events.
SR16VE
Intake Low: Opens at 0deg before TDC, Closes at 20deg After BDC
Intake High: Opens at 40deg before TDC, Closes at 60deg After BDC
Exhaust Low: Opens at 64deg before BDC, Closes at 0deg After TDC
Exhaust High: Opens at 70deg before BDC, Closes at 30deg After TDC
SR16VE-N1
Intake Low: Opens at 0deg before TDC, Closes at 40deg After BDC
Intake High: Opens at 40deg before TDC, Closes at 68deg After BDC
Exhaust High: Opens at 74deg before BDC, Closes at 34deg After TDC
Thanks to FastNX ,92nx2k and hpro123 for the information
The community is here.
Old 05-04-2007, 12:50 AM   #2 (permalink)
SR's are a fad
what lift is the duration being measured at?
rage is offline   Reply With Quote
Old 06-19-2007, 09:11 PM   #3 (permalink)
But what does it all mean Basil!? Sorry I'm tring to find what overlap is and the searching is giving me a whole lot of info that is way over my head and explains nothing grrrrrrrr
Tania86 is offline   Reply With Quote
Old 11-15-2007, 03:49 AM   #4 (permalink)
VVL Junkie
anybody has the info about vet cams?
Nissan Pulsar Gti-R'91
VZ-R`97 sr20ve, n1
nice n15 frp hood for sale!
DeNismo is offline   Reply With Quote
Old 11-15-2007, 11:26 AM   #5 (permalink)
Feedback Score: 51 reviews
SR20VET
Intake cam
Low lobe: 8.0mm lift @ 212 duration
High lobe:11.0mm lift @ 248 duration
Exhaust cam
Low lobe: 11.3 mm lift @ 244 duration
High lobe: same
The VET has 13 degrees of overlap on the high-rpm-intake cam and single exhaust cam. There is no overlap with the SR20VET on the low-rpm-intake cam and single exhaust cam.
99 Sentra SE-L, sr20ve 20V, 6spd P12 transmission with HLSD, n1 cams, 20v header w/ protech downpipe, calum realtime v2, 949 6ul rims, 11.75" wilwoods, VZR front end
My Ride:
http://www.sr20forum.com/members-rid...-vzr-6spd.html
Garage Cleanup Sale:
http://www.sr20forum.com/forced-indu...arts-sale.html
iczer200sx is offline   Reply With Quote
Old 02-14-2008, 04:02 PM   #6 (permalink)
Is there a part number for the SR20VE (20V)? Is this a US buy or Japan only? G Spec does not list this cam. Hello, anyone home?
Don Kadunc is offline   Reply With Quote
Old 02-27-2008, 12:59 PM   #7 (permalink)
cam specs for the VET is abit Disappointing
STR8E180 is offline   Reply With Quote
Old 02-27-2008, 02:57 PM   #8 (permalink)
VE-T tester
Feedback Score: 3 reviews
What will work best for turbo? I have the stock sr20ve cams and they have less overlap than the 16 cams, but I get reversion when the cams switch? What cam would give the best spool characteristics and power within an 8k rev limit?
I am told to take out 10 degrees of overlap first to see how it does but I don't know much about cams and stuff. What would make a potent turbo cam as far as cam selection and cam timing?
99 SE-L. Graphite Gray GT3076R .78 Twin scroll turbo, Custom Twin scroll tubular manifold, 3" all the way! Nismo FPR 740cc, 255 pump, JWT computer. Dyno soon!
Coheed is offline   Reply With Quote
Old 03-01-2008, 01:21 AM   #9 (permalink)
VE-T tester
Originally Posted by exxd View Post
This combo will have 60* overlap vs. the having 70* overlap with both 16ve cams.
The 60* overlap is with the 16ve intake cam centerline at 100*ATDC and the 20ve exhaust cam centerline at 114*BTDC.
While I'm at it, More VE camshaft overlap:
SR20VET - 13*
SR20VE - 48*
SR20VE 20V - 57*
SR16VE - 70*
SR16VE - N1 (v1?) - 78*
edit: added vet cams
Figured this would help this thread.
Old 03-04-2008, 11:19 AM   #10 (permalink)
The 20V cam is from a European Primera SSS. How can we get it here?
Old 05-07-2008, 11:06 AM   #11 (permalink)
VE-T tester
VET cams may look a bit low on the duration side of things, but the lift is where it's at. They seem to look perfect for turbo. I guess I will find out.
Old 11-19-2009, 12:14 AM   #12 (permalink)
can anyone help me
The SR20VE and SR16VE can be interchangeable cam shaft
raymondgo is offline   Reply With Quote
HTML code is On
