How the VVL works - Page 3 - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > NeoVVL Guides
Old 10-07-2005, 11:16 AM   #41 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
Originally Posted by FastNX
Supercowboy:
Is lash adjusted by variable thickness shims like the DE head? Will the DE shims work with the VE?
Another question: I am interested in using the VE head, but class rules stipulate
variable valve timing and lift devices are illegal, although they can be used if the variable part is eliminated. Would it be possible to lock the rockers together so that it always uses the large cam profile?
You can wire the solenoids to always be on. The car will idle like crap and have no low end power though.
The community is here.
Old 10-08-2005, 02:40 AM   #42 (permalink)
Professor Dingbat
Feedback Score: 14 reviews
This is a race only car, I do not care about power below 4500 RPM.
I am looking for someone who has experience with the internals of this cylinder head like Supercowboy.
Old 10-08-2005, 02:49 AM   #43 (permalink)
retired
Feedback Score: 9 reviews
Jeff do you remember the guy that has the p11 race car(yellow, ve,serious carbon fiber intake manifold?) I think he has some BIG cams that eliminate the VVL since vvl is prohibited in ther class he races in.
NOT SR20 POWERED
needs.
Old 10-08-2005, 02:50 AM   #44 (permalink)
retired
http://www.sr20forum.com/showthread....hlight=p11-144
Old 10-08-2005, 02:51 AM   #45 (permalink)
Professor Dingbat
I do remember it yes, I was just wondering if it's possible to lock the rockers together permanently. All VVL apparetus must be removed, including the solenoids. I'm not even going to run an extra oil line to the head, just lock them together so it's awlays on the big lobe.
Old 10-08-2005, 03:02 AM   #46 (permalink)
retired
If you can figure out an easy way to lock the pins im sure that would work. Could use remove the solenoids and run an oil line to the head so that the pins have constant pressure?
Old 10-08-2005, 03:03 AM   #47 (permalink)
Professor Dingbat
I guess I'll have to get one and take it apart to find out. Should me more reliable than spinning the DE to 8 grand.
Old 01-09-2006, 07:09 AM   #48 (permalink)
VVL Junkie
Hmmm...
Does it mean that it would be no problem if I operate both cams in the same time on the "older" VE motor?
e.g. I'm trying to make a Greddy E-Manage work on the sr16ve. It has only one VTEC stage... and it might work in than case. Am I right?
Nissan Pulsar Gti-R'91
VZ-R`97 sr20ve, n1
nice n15 frp hood for sale!
DeNismo is offline   Reply With Quote
Old 01-09-2006, 07:23 AM   #49 (permalink)
retired
Originally Posted by DeNismo
Hmmm...
Yes you can activate both cams at the same time, alot of us do it. You can also use the greddy e-manage to activate you vvl. Just make sure you use a relay otherwise you will fry the board.
Old 01-09-2006, 07:49 AM   #50 (permalink)
VVL Junkie
Can you give more detailed description how to do it or the refer to it?
Please!
And what is the relay?
Old 03-22-2006, 10:28 PM   #51 (permalink)
SR20DEtroit
Feedback Score: 10 reviews
Interesting... still confused as ever whether to go VE or T28...
sonny is offline   Reply With Quote
Old 03-24-2006, 08:34 PM   #52 (permalink)
You want how many lengths
Very sweet explanation on the VVL system, but one thing I have been researching but haven't been able to find is how the camshafts operate independently of each other, unlike the Honda VTEC system?
LONG LIVE THE SR20!!
DRIFTING THE ABSTRACT!!
nxgripspec is offline   Reply With Quote
Old 03-24-2006, 09:14 PM   #53 (permalink)
Is an SE-R/VE a VE-R?
Two different solenoids - one for each cam - I'm just using one switch for now (msd 8969 is a common approach) at 4600, spins the tires in 1st when it hits the cams. REALLY serious people use two 8969's (or another switch) as the motors build power a bit better when the intake cam switches about 42 and the exhaust 48 or thereabouts depending on the setup (but others argue switching the exhaust first ) The best VE man in America is Andreas Miko; you'll find him here and his signature has his fone #. If you want to get into this give him a call.
'93 B13, etc.
do it over and over again?
Old 03-24-2006, 09:22 PM   #54 (permalink)
And Sonny, depends on what ya wanna do. The VE seems to be more reliable, you're not fixing pumps (or blown up motors) all the time. If you wanna go in a straight line, maybe a pump motor. But if you want to use the car as intended, which is to say go around corners, and/or most of your driving is, um, spirited street, I recommend (a) a VE and (b) talking to Andreas. That's not just me; others may chime in; esp. if you're on the right half of the country (he's in FL and shipping DOES cost $) his reputation for doing EXACTLY what he says he's going to do is flawless.
Old 04-16-2006, 01:20 AM   #55 (permalink)
Professor Dingbat
Something I noticed the other day is that the cam bearing caps are numbered! Even if you mix them up, you can still put them back exactly as they were
This motor rocks!!!
Old 07-28-2006, 02:18 AM   #56 (permalink)
'71 240z, a REAL classic
what to do about replacing the shims? mine fell out cleaning the head.
Lunar240z is offline   Reply With Quote
Old 07-21-2007, 01:44 AM   #57 (permalink)
Rockin' the GA
Sorry to dig up an old thread but i have a nissan nx 1600 and ive been on the site awhile now. Anyway i have been juggling back wiether or not to swap it for a sr20det or to try to turbo it. Well i was reading about the sunn 1.6vvl. IS there a way i can change the old gas16de to the 1,6 vvl at a more cost affective approach than an engine swap or turbo but still see some nice performance gains?
Nx1600man is offline   Reply With Quote
Old 07-21-2007, 03:02 PM   #58 (permalink)
honda copy cats!!!!!! but i still like my nissan
g20_det is offline   Reply With Quote
Old 12-05-2007, 10:01 AM   #59 (permalink)
use vvl head on a gti-r bottom end?
gt30rsunnygts is offline   Reply With Quote
Old 12-05-2007, 08:34 PM   #60 (permalink)
On The Go!
what does the vvl do?
1997 200sx w/SR20VE
pr71385 is offline   Reply With Quote
HTML code is On
