How the VVL works - Page 4 - SR20 Forum
Go Back   SR20 Forum > What's New > Technical Information Library > NeoVVL Guides
Old 05-12-2008, 07:58 PM   #61 (permalink)
a fella was tellin me *** in his build over of the motor the mechanic didnt mark the shims on the valve stem an well now his engine is soundin like a diesel. *** is the correct clearence for this engine? intake an exhaust. an is it adjusted *** as a de by removin shims an replacin?
i am guessin *** the correct shims are in the engine right now but it is *** a matter of checking the clearences and removin the shims an measuring *** 2 get correct size in order 2 place *** back in correct places?
turbohead is offline   Reply With Quote
Old 07-25-2008, 03:47 PM   #62 (permalink)
FWD PWNAGE IS HERE!
Feedback Score: 10 reviews
where are the pictures at?
'93 240SX - Stock for now
'95 G20 - The DD - 210K and counting
'96 G20 - Beating up the streets of SL,UT.. watch out - 334WHP/313TQ
www.UtahNissans.com
www.RallySportDirect.com
SR20 Inside is offline   Reply With Quote
Old 07-28-2008, 02:09 PM   #63 (permalink)
The Super Mechanic
supercowboy's Avatar
Feedback Score: 9 reviews
There back up now
06 monaro cv8
91 ser 311whp@15psi
CT SUPERHERO
DO YOU KNOW WHO I AM!!! I THOUGHT SO!!!!
supercowboy is offline   Reply With Quote
Old 07-28-2008, 05:26 PM   #64 (permalink)
FWD PWNAGE IS HERE!
thank you sir
Old 11-07-2011, 01:57 AM   #65 (permalink)
1st gen and 2nd gen
Hi Guys,
do anyone knows when the independent electronic control of the exhaust and intake valves has been introduced ?
i am buying a SR20VE halfcut from a P11 primera and would like to know if i can make it independent like the P12 nissan primera 20V.
do i need to change the ECU ?
has anyone know if besides this and the camshafts, if there are any other differences ?
froes is offline   Reply With Quote
Old 12-17-2011, 06:00 PM   #66 (permalink)
My VVL, particularly the exhaust side, sounds like it kicks in and out quickly around 4k then quits until about 6k. All this with no power going to either solenoid and both are new.
Is it possible that VVL can kick in without the solenoid? Or what else would sound like that?
zerosin is offline   Reply With Quote
Old 03-02-2012, 09:54 PM   #67 (permalink)
vvl in nx2000
do you have a vvl in an nx2000?
if so what mods did you have to take into consideration when making the swap from the stock motor?
I cannot find this information anywhere I look
kquicksilver is offline   Reply With Quote
HTML code is On
