Go Back   SR20 Forum > What's New > Technical Information Library > NeoVVL Guides
Old 03-10-2004, 07:52 AM   #1 (permalink)
The Super Mechanic
supercowboy's Avatar
How the VVL works
Pic #1
Pic#2
Pic#3
Pic#4
Pic#5
Here is a quick explaination of how the VVL valvetrain works. If you notice in pic#5 (The shaft in the center). This shaft runs through the head from one end to the other. This shaft does not spin and is staked by a small bolt at the cam gear side of the head. There is a Channel that runs the length of the shaft. The end of the shaft is blocked off. There are four feed holes, which are located at each rocker arm location. The rocker arms are located on a pair of valves. The other end of the rocker arm pivots on the shaft. Notice The "whole" or the channel the shaft runs through (Pic#1). As the solenoid(top of pic#5) is activated, there is a passage in the head that opens and allows the oil to pass through the shaft. At this point the oil passes through the feed wholes (Notice pic#2) into the rocker arms. This pushes the pin foward in the rocker arm. (notice pic#3) This locks the center part of the rocker arm which enables the center cam lobe. Notice pic #4. This engine works completely different than a DE. There are no "lifters" pushing the rocker arms up. The shaft is machined at the proper height for the rocker to swivel or rotate on. The lash adjustment is adjusted by the shims on top of the valves. This is a completely mechanical operating system. The only hydraulic part of this set up is the pin which enables the center part of the rocker arm to activate.
I hope this is a good explaination for those of you who do not understand how this works. I will post a pic of the head complete.
06 monaro cv8
91 ser 311whp@15psi
CT SUPERHERO
DO YOU KNOW WHO I AM!!! I THOUGHT SO!!!!
supercowboy is offline   Reply With Quote
Old 03-10-2004, 08:16 AM   #2 (permalink)
WASHED UP
Re: How the vvl works
Nice.Never knew that.
Old 03-10-2004, 11:02 AM   #3 (permalink)
seen the light
This is why the VE will rev quite high then?No HLA's to get in the way of high revs...How often will the shims require attention/replacement?
Good pictures, supercowboy, cheers.
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
Old 03-10-2004, 03:20 PM   #4 (permalink)
VE junkie
yea does that mean we will need to get the valves adjusted every 60k like a honda motor? and who knows how to do it, and the proper specs...since there no hydraulic lifter.
Old 03-10-2004, 04:37 PM   #5 (permalink)
aka Mr Ryte on G20.net
Interesting....
Well, that certainly clarifies a lot of things.
Vehicle:1995 Dark Green Infiniti G20
Real name:Howard Wright
Current mods:91 intake cam at 19* degrees, TopSpeed header, M3-style rear wing, P11 rims, *Recaro LS-L seats*
I.C.E.:Pioneer DEH-P6800MP CD/MP3 HU, Audiobahn AS65Q 6.5" components in front & back....HELLZ YEAH!!!!
"THOU SHALT NOT MOD THAT WHICH THY CANNOT MAINTAIN" -thus speaketh Mr. Ryte
howard_w13 is offline   Reply With Quote
Old 03-10-2004, 07:21 PM   #6 (permalink)
The Super Mechanic
There should not be any adjustment. You can check lash to make sure it is in spec. I havent heard of people adjusting the lash from wear. You would have to adjust lash when the machine shop does a valve job.
06 monaro cv8
91 ser 311whp@15psi
CT SUPERHERO
Old 03-11-2004, 03:19 AM   #7 (permalink)
wow, that's great and surprising me. I thought the lobe is on the cam shaft previousely.
b11boy is offline   Reply With Quote
Old 03-11-2004, 06:21 AM   #8 (permalink)
Pulsar 20V
hi, is there anyone know if a adjustable cam pulley is needed with a SR20VE 20V cam swap?
PennyFan is offline   Reply With Quote
Old 03-11-2004, 09:08 AM   #9 (permalink)
Egger
very cool pics
NXFuer is offline   Reply With Quote
Old 03-11-2004, 09:44 AM   #10 (permalink)
The Super Mechanic
You can use a adjustable pully on anything. To make it right you really have to degree it to put it in the right spot. Then you can adjust it on the dyno.
06 monaro cv8
91 ser 311whp@15psi
CT SUPERHERO
Old 03-11-2004, 11:04 AM   #11 (permalink)
"Keep firing, Assholes!"
tystyx49's Avatar
excellent pictures and explaination. i was always kinda wondering how it worked. i'd need to see it in person to really get it though.
93 SE-R with some things and such...
tystyx49 is offline   Reply With Quote
Old 03-11-2004, 11:16 AM   #12 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 84 (100%)
Very enlightening, thanks for posting that.
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Government run health care = fail
Old 03-11-2004, 04:03 PM   #13 (permalink)
JRios's Avatar
Good job Supercowboy
Jorge
1996 SE-R
Old 03-16-2004, 03:34 PM   #14 (permalink)
Too busy to post
Very Informative. Thanks
91 VE-R - One Off
NeedMore$4SE-R is offline   Reply With Quote
Old 03-17-2004, 06:59 AM   #15 (permalink)
very good info...never knew the VE valvetrain was mechanical..
a VE, still a dream for now...
b12sr20ve is offline   Reply With Quote
Old 07-14-2004, 03:19 PM   #16 (permalink)
kW lover
Sticky?
jerseyj is offline   Reply With Quote
Old 07-14-2004, 08:00 PM   #17 (permalink)
yup
agreed... this is very very sticky material... as in this post should be made a sticky
black 93 classic
Old 07-14-2004, 08:44 PM   #18 (permalink)
Off-Topic lurker..
Wow, that's great! I just learned something.
silversx is offline   Reply With Quote
Old 07-15-2004, 12:22 AM   #19 (permalink)
yup
Alright! its a sticky!
black 93 classic
Old 07-16-2004, 08:19 AM   #20 (permalink)
nice!
HTML code is On
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
