Go Back   SR20 Forum > Main Forums > New Members
Old 05-09-2008, 07:48 AM   #1 (permalink)
Deathtoal
SR20DET in '88 Sentra ZXE
I have a 1988 Nissan Sentra 1.6 ZXE. I was wondering if it was at all possible to put an SR20DET engine in my car. If so then what needs done to fit it in, engine mounts etc.
Also since all of the SR20DET engines i can find are in RWD cars or have an inline transmission on them, i was a bit confused whether I could put a transaxle gear box on it and mount it hopefully on the same mounts as the previous engine, or if i might have to convert it to RWD. I would then need a custom made drive shaft and possibly the rear axle as well which would get expensive.
If anyone can enlighten me on this subject I would be most grateful.
Thanks
Deathtoal is offline   Reply With Quote
Old 05-09-2008, 07:51 AM   #2 (permalink)
james23nyc
G20 DET
look for a SR20DET from a bluebird or avenir, or gti-r, those are fwd/awd engines, you cant use a rwd sr20
'96 G20-SR20DET/5spd swap/K-Sport Coilovers/Custom FSTB/Octotat RSTB/Walbro 255lph/N60 MAF/Calum Ecu/AFPR/Skunk2 3in muffler/3in catless exhaust/Autometer Boost Gauge
james23nyc is offline   Reply With Quote
Old 05-11-2008, 11:36 PM   #3 (permalink)
Deathtoal
ok thanks for the info. I'll have a look around and see what I can find
Old 05-11-2008, 11:39 PM   #4 (permalink)
Deathtoal
Do you know if that engine will drop straight in with my current engine mounts or will they need changed?
Also, will the gearbox that's in it now be alright or should I find one to suit the engine?
Old 05-11-2008, 11:42 PM   #5 (permalink)
Nyc Sr20PowerD
Trader Rating: 15 (94%)
mounts will have to be modded
Project Shift_Rebirth
Nyc Sr20PowerD is offline   Reply With Quote
Old 05-12-2008, 12:09 AM   #6 (permalink)
Deathtoal
Thanks mate
