Nissan primera p11 from Bogota - SR20 Forum
Go Back   SR20 Forum > Main Forums > New Members
Old 01-11-2012, 06:04 PM   #1 (permalink)
hello friends
My name is Jose Gonzalez, I have a nissan primera p11
Currently my car has a problem, when the car accelerated and then slows down normal speed again, as if to drown and, I really do not know what may be, clean the injectors, changing the knock sensor, the throttle body is clean, the maf works well
I hope to help me and not much about this car
thanks
jose gonzalez is offline   Reply With Quote
Old 01-25-2012, 10:26 PM   #2 (permalink)
Hey I have a 2001 g20t...when u did the swapp what did u do about the engine wiring harness problem..did u get it custom made????
jum871706 is offline   Reply With Quote
Old 01-26-2012, 12:30 AM   #3 (permalink)
check your MAF connection
it could be the pins in the connector plug to the maf could have gone in a little and are not having a proper connection
check your voltage to the maf and make sure your maf has a good ground
if this checks out then make sure you don't have a vacuum leak all the way from the airfilter to maf-turbo-intercooler-intake manifold
rusconnections is offline   Reply With Quote
Old 01-26-2012, 01:57 AM   #4 (permalink)
I haven't put in the engine yet but i was refering to my car being obd2 and the det obd1
