» Auto Resources
Find new Nissan car reviews on Nissan Maxima, Nissan 350Z, and more. View pictures and guides on Nissan cars like a Nissan Altima.
» Sponsor Links
»Garage Storage and Cabinets
Go Back   SR20 Forum > Main Forums > New Members
Old 04-16-2004, 12:58 AM   #1 (permalink)
owned by 'hybrid axle'
plug gap
can someone explain this term and how to gap plugs and such. im in the dark on ***
*INSERT NEGATIVE COMMENT TOWARDS RICE HERE*
http://www.imagestation.com/picture/...9/f8693251.jpg
maxpower is offline   Reply With Quote
Old 04-16-2004, 12:12 PM   #2 (permalink)
Coropate greed hater
Re: plug gap
There is a gapping tool to set the proper gap on plugs, which you can purchase for cheap from an auto parts store. The tool has measurements on it so you can adjust the plug to the desired gap. You'll know that you have the correct gapping when the tool goes in and out of the gap with a little bit of friction. The procedure is not tough at all. However, you should be careful while bending the electrode. It's quite soft and can break easily if you put exert too much force on it.
-The Usual Suspects
Old 04-17-2004, 06:19 AM   #3 (permalink)
Re: plug gap
so if you widen the gap. there is more spark area but less spark power?
how can you tell what gap best suits a set-up?
Old 04-17-2004, 10:08 PM   #4 (permalink)
Re: plug gap
Widening the gap delays the spark, and closing the gap quickens the spark, because of the distance between the tip and the electrode. Use the FSM-recommended gap for best results.
Old 04-18-2004, 03:38 AM   #5 (permalink)
Re: plug gap
great! now. on most turbocharged cars. gaps are closed more right. or not right.
side question. does improper gapping cause detination, are contribute to it?
Old 04-19-2004, 10:13 AM   #6 (permalink)
Re: plug gap
I know they use "colder" plugs than N/A guys due to the immense heat produced by turbocharged motors. Gapping should only be changed if you modify your ignition system. AFAIK, the DEs and DETs have the same gapping as recommended by Nissan.
Yes, improper gapping can contribute towards detonation. That millisecond difference in the distance travelled to make the spark is HUGE. Incorrect gapping can cause other problems that will prevent the motor from running properly.
You have to remember that ignition timing is set based on the assumption that the plug has been gapped properly. That's why it's imperative that the plugs are gapped according to manufacturer recommendations. It doesn't matter if you're N/A or turbo. It's one step that no one should look over.
Old 04-19-2004, 07:22 PM   #7 (permalink)
Re: plug gap
oh my. thanks for that info. ill be sure to pm you when tuning my det!
Old 04-21-2004, 04:29 AM   #8 (permalink)
GT2835R
Re: plug gap
I find that wire type gappers are the best.
Rey Uy
99 SE-Limited
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
