Old 02-21-2007, 05:03 PM   #1 (permalink)
pulsar gti-r owner
gtir 4 x 4 system
remebered this during a discussion on another gtir forum..Might be of interest to some of you.
credited to krazeguy
OK!!!! I have finally figured it out once and for all. Now ill try to explain this as best I can. This actually works in a VERY simple yet sophisticated way. There is just your average run of the mill differentials that controls the torque split. On your average diff you have a bunch of spider gears. For those that don't know the spider gear on one side controls the left wheel and the spider gear on the other side controls the right wheel. When your driving along in a straight line these gears spin together at the same rate, but when you turn, the spider gear on the inside starts to give way and allow the outter side to rotate more.
So most people know the workings of an open diff. Now the problem with an open diff is that if your driving in a straight line and you loose traction, one wheel will get all the torque leaving the other one with nothing. To combat this some diff's have a spring type clutch between the spider gears, this locks the two spiders together but still allows either spider gear to 'fall behind' a little when turning a corner. These are reffered to as a Limited Slip Diff.
Open
LSD
Another type of Limited Slip Diff, does away with the spring system between the spider gears and makes use of a Viscous Coupling. (VLSD) The way this works is that you have the right spider gear controlling the right wheel, and the left spider gear controlling the left wheel. But connecting to the left spider (/axle) is a little unit. This unitr connects directly to the Final drive (/diff casing) and inside the unit is a series of plates connected to the casing, then another series of plates connected to a gear. Between these plates is a Viscous fluid which thinkens as friction between the plates increases and heats the fluid. So if you loose traction in a straight line (or round corners for that matter) and the right wheel is spinning, the plates in the viscous coupling (which are connected to the final drive gear) start spinning, heat the fluid and bind up with the other plates which are connected to the left spider gear, which in turn, 'catches up' the left wheel so both wheels are spinning ... which of course means more traction.
Now the T4/GTIR 4WD system takes the VLSD principle and instead of using it to control left and right wheels, It controls Front and Rear. The final drive gear connects to the VLSD, the right spider gear connects directly to the transfer case which drives a reduction gear (about 4:1 by doing a rough test) which then goes to the rear wheels. To meet up to another VLSD to control Left and Right rear wheels. Then you have the Left spider gear to control the front wheels. There is an axle running through the right spider gear to the left one which goes through the transfer case to spin the Front diff. The front diff controls torque between Left and Right front wheels. (This diff is open, so if you are on grass and drop the clutch only 3 wheels would spin. The two rear wheels and one front wheel.)
I might have lost some in that last paragraph. But as I was saying the left spider gear controls the front diff, now if that 'Centre' diff was open then when you lost traction only the front or only the rear wheels would spin. Which would mean its not really a very good 4WD system. But the centre diff is VLSD so as the right spider gear spins (rear wheels) then the left spider gear (front wheels) has that little viscous coupling along with all its plates and fluid to help bring the front wheels up to speed.
Right, so hopfully you got that. Then you might be wondering why the T4/GTIR promotes under steer while going round a race track, or on the dyno etc. This is probably because of the reduction gear in the transfer case. case that transfers the to the rear wheels. So as the left spider gear (front wheels) catch up and viscous coupling is all bound up then the front wheels start getting more direct power and the rear wheels get slightly less simply because of the gearing in the transfer case.
Kieron is offline   Reply With Quote
Old 03-07-2007, 12:15 AM   #2 (permalink)
PWND by SR20's
I love NISSAN Technology
Jeremy
_LOVIN VT_
VT Tech College Graduate w/ an Associates Degree in Automotive Technology
Technician at South Burlington NISSAN
First 2 cars__SE-R's
1st carAge 14_ Black-93 Sentra SE-R (Sold)
2nd carAge 15-present_ Black-95 200sx SE-R_GTi-R
Retro Cruiser
White-87' Honda Accord LX-I Hatchback
haasyboy25 is offline   Reply With Quote
Old 03-07-2007, 05:48 PM   #3 (permalink)
This is why when going to a dyno you havbe to check that the front and rear rollers are linked, if they aren't then the front can get so much power that the viscous part of the center diff gets overpowered and you can damage the viscous part so it doesn't work properly (this might show immediatly or in several thousand miles....and even then you probibly won't notice anything when driving the car).
To check if the center diff is still working properly, jack up the rear of the car so the tyres are just off the floor, put it into gear with the engine running and very slowly let the clutch out. if you go nowhere and the rear wheels are spinning the viscous ctr diff is knackered, if you move forward (be careful not to come off the jack) then the diff is ok.
This also happens to Scoobies too.
stumo is offline   Reply With Quote
Old 03-07-2007, 09:34 PM   #4 (permalink)
Sc61 in works
Trader Rating: 24 (100%)
^ that is a terrible method to see if your center diff is good shape and I cant imagine anybody who would do it like that.
just "be careful not to roll off the jacks.."
Sc61 Se-R Sold..
Originally Posted by SlidewayS15
Isn't the Sentra A FWD.....The SR20det is a RWD motor
Originally Posted by Salvisol82 View Post
I'll Tell you one thing. Jenna Jameson has one of the ugliest looking vaginas I've ever seen. From a lower front view it looks like she has a tiny nutsac.
B14 Se-Rious is offline   Reply With Quote
Old 03-08-2007, 04:56 AM   #5 (permalink)
Hmmm I wonder what the difference will be like with a carbon drive shaft on the gti-r...less rotating mass, less drivetrain power loss, less loading shock on the gearbox...etc etc..
carle is offline   Reply With Quote
Old 03-08-2007, 10:12 AM   #6 (permalink)
There's a groupby going on at nissangtir.co.uk right now.. a carbon shaft would be great... but out of my budget range
nickr is offline   Reply With Quote
Old 03-08-2007, 11:24 AM   #7 (permalink)
pulsar gti-r owner
its a common way of doing it, at the end of the day you need the rears just high enough off the ground so they can turn freely, worse case scenerio the car moves forward and plops to the ground all of 10mm, not exactly that much to worry about.
its not like you hold it at 7000rpm and dump the clutch whilst the rear wheels are 2 feet up in the air
Old 04-05-2007, 11:55 AM   #8 (permalink)
allmotorKA24DE
thinnertenor's Avatar
so what would be the solution to put more power more constantly to the rear wheels?
maybe a harder locking center diff?
or a differant(lower) ratio b/t the front and rear?
B.J. Walker
1993 Aztec Red NX2000
1993 White 240sx Hatchback
thinnertenor is offline   Reply With Quote
Old 04-16-2007, 01:06 PM   #9 (permalink)
54C PWNS ME
An electronically controlled center differential with power split to front and rear.
From what I know the GTI-R uses the Nissan attessa system which is electroniclly controlled. How do the electronics come into play with this AWD system?
1993 NX2000
JimmyNX2000 is offline   Reply With Quote
Old 04-16-2007, 01:49 PM   #10 (permalink)
They don't. It's all mechanical
CLICKY
Fast Guy is offline   Reply With Quote
