Old 03-06-2007, 02:12 AM   #1 (permalink)
gti-RpowerdG20
gti-r coil aftermarket?
is tehre an aftermarket coil for teh gti-r motor? i have been searching for about 3 months but havent coem up with anything.
G20SR20det is offline   Reply With Quote
Old 03-06-2007, 03:03 AM   #2 (permalink)
SE-R Turbo Slut
Trader Rating: 29 (100%)
If your stock one is busted it shouldnt be too hard to get a replacement.
If your just seeking a littel better response or reached the limits of your stock igntion i would suggest crane cams dsr igntion and coil.
Larry Low
LAMO IMPORTS
k6 GSXR 750
01 Ducati 996
1999 sentra se-l
1992 Pulsar Gti-r
Low612 is offline   Reply With Quote
Old 03-06-2007, 07:14 PM   #3 (permalink)
gti-RpowerdG20
looking to upgrade just loking for a coil ***. can i use just teh coil crane cams makes?
Old 03-07-2007, 12:55 AM   #4 (permalink)
SE-R Turbo Slut
yes you can
Old 03-07-2007, 04:50 AM   #5 (permalink)
gti-RpowerdG20
i did some reaserch but i want to be sure the one i buy is correct. im looking for teh one that is a direct replacement for my factory coil on my gti-r motor.
Old 03-07-2007, 05:05 AM   #6 (permalink)
SR 20 Site newbie
Buy a new standard one from Nissan.
Rob
vpulsar is offline   Reply With Quote
Old 03-07-2007, 10:51 AM   #7 (permalink)
SE-R Turbo Slut
Hes looking to upgrade though...^^^
Old 03-07-2007, 11:00 AM   #8 (permalink)
SR 20 Site newbie
You can fit the MSD SS blaster coil to the pulsar and it will work with the standard stuff.
A few of our members have done just that, Myself I'm fitting a new MSD box and coil.
Rob
Old 03-07-2007, 10:02 PM   #9 (permalink)
gti-RpowerdG20
anyone have any install instructions for that msd coil or is it plug and play?
Old 03-07-2007, 11:12 PM   #10 (permalink)
SE-R Turbo Slut
Its just a positive and neg wire....for the blaster or crane. I would recommend the crane if you plan to use crane ignition in the future as its better casing quality as well. I use the blaster ss on two of my turbo setups i was happier with the crane. Your choice either will do .
Old 03-08-2007, 09:31 AM   #11 (permalink)
gti-RpowerdG20
do you have the part # for the crane coil witch works with my set up?
Old 03-08-2007, 10:49 AM   #12 (permalink)
SE-R Turbo Slut
LX-92 coil
Old 03-08-2007, 11:50 AM   #13 (permalink)
gti-RpowerdG20
this one?
http://store.summitracing.com/partde...5&autoview=sku
Old 03-08-2007, 05:10 PM   #14 (permalink)
SE-R Turbo Slut
das it ..also get the high vibration mounts
Old 03-14-2007, 07:34 PM   #15 (permalink)
CAR SLÜT
LX92 wont work with the stock power transistor. The LX91 is the only one that works without adding the Hi-6 system.
http://forum.pulsar.org.au/showpost....&postcount=116
VY SS Ute: Stealth TT LS1 V8 with Tein coilovers, Boyd Coddington 19" Turbines & HKS EVC 6 with PICS
3.5L V6 N14 Pulsar - In a class of its own on the track
R34 GT-R Skyline - Blitz Bodykit, 19" Volk GT-C's and new massive cube engine being trial fitted this weekend
iamhappy46 is offline   Reply With Quote
Old 03-15-2007, 02:22 AM   #16 (permalink)
SE-R Turbo Slut
How strange it worked on mine when i decided the blaster was junk. Although i did add a crane hi-6 dsr ignition 5months later
Old 03-15-2007, 09:39 AM   #17 (permalink)
CAR SLÜT
Check the Crane website, it specifically states that the LX92 needs to be used with some form of ignition booster to work.
Old 03-15-2007, 11:03 AM   #18 (permalink)
SE-R Turbo Slut
Well from my experience it worked and caused no problems . Car actually was crisper with it compared to the baster . IM only speaking from my actual on hands exeprience , like mentioned i did add the igntion later on as well. I didnt need a booster for it work either.
Old 03-15-2007, 12:32 PM   #19 (permalink)
SE-R Turbo Slut
if you plan on upgrading the igntion in future get the lx92, if you plan on sticking to stock ignition get the lx91. or just upgrade all at once.
Old 03-19-2007, 01:12 AM   #20 (permalink)
gti-RpowerdG20
well igues i should have read this thread earlier huh i installed teh lx92 and the car runs like dog sh!t. i was checking for boost leaks and all sorts of things but igues its teh coil ill have to undow everything i did and put the stock coil back.
