Here is a List of part numbers for the Pulsar GTIR. I will see about getting FAQ done
Larry Low
92 Pulsar GTI-R BLK Gab upper strut brace, Cusco 4pt Front underbrace, front/rear skid plate, stock rear rollbar, full tein coilover suspension , tein camber plates and thats about it for now. Pm me if you need GT Turbos or ano other type. http://s294.photobucket.com/albums/mm106/low612/
LAMO IMPORTS
k6 GSXR 750
08 Ducati 1098s Black
1999 sentra se-l
1992 Pulsar Gti-r
if you want any part numbers just ask, i've got the fast system. u'll just have to ask your dealership to find the updated part numbers if there are any.
heated 02 sensor 22690-54c00 list price CDN$ 201.77
toe hook cover
Tow Hole Cover 10/90 - AJ4 62228 62228-54C00
Tow Hole Cover 10/90 - KH3 62228 62228-54C02
Tow Hole Cover 10/90 - TJ1 62228 62228-54C03
Tow Hole Cover 10/90 - KJ7 62228 62228-54C04 List price CDN$ 69.31
Tow Hole Cover 10/90 - 531 62228 62228-54C05
Tow Hole Cover 10/92 - FM0 62228 62228-74C02
turbo outlet to dump pipe gasket 14445 26e00 List price CDN$ 28.22
turbo outlet stud x 2 14414-17F00 list price cdn$ 9.38
turbo outlet stud nut x 2 14432 0B700 list price cdn $3.55
turbo bolts x 3 14434 V0301 List price cdn$ 4.87
rear cargo shelf holder bracket/clip 79914 61Y00 x 2 list price cdn$2.91
dashboard metal spring clips that hold the dash pieces in 68192 62c00 list price cdn $2.68
** note i may have the part numbers in reversed for the following two belts, not sure
power steering belt, waterpump belt 11920 53J01 list price cdn$ 33.00
alternator belt with ac 11950-54C00/ replacement number A1950 54C00 list price cdn$40.55
great stuff!! We just need to get updated USA numbers most of the body parts wont work in the US. Do thebody part numbers like windshiel and so forth work in Canada?
The Nissan dealer here just puts an order through to Nissan Canada. They can get anything from Japan, just that there is a no return policy on them. Usually takes 2-3 weeks to bring it in.
The windshiled, clip, and molding all came from japan, i just supplied them the part number.
and i will add a US parts number for something a lot of you guys may want:
the air conditioning unit is a lot of weight off of the front end if you get rid of it. i think that after i removed everything off the block and out of the dash it weighed out to about 40 lbs! however, if you decide to get rid of the A/C you will need a smaller diameter belt. the belt you need can be found at napa. it is a gates brand belt: gates part #K050330. it is a 5 rib belt one rib less than the standard one. but you wont have the a/c compressor anymore so its ok. i have been running this belt for 2 years with no probs. now go out and get rid of that A/C!
i paid roughly 770$ canadian, inclusive of sales taxes. so take off about 13.5%
i bought this before i made a friend who worked in nissan parts, so i could have got it for much less.
i felt the price was worth it anyways, as they bore the burdon of risk of shipping.
i can source glass for roughly 250$ canadian in japan, its not oem, but aftermarket china made glass. however, the cost of shipping and risk involved easily exceeds the cost of what i paid through nissan.
if someone wants to arrange getting stock of this glass i can put u in touch with the supplier. however, you'll have to speak japanese and convince him to ship overseas. or if you know a vehicle importer you can put it into a container.
-- another part
rear quarter window handle/latch 83610 50c00
the spark plug wires, distributor cap, rotor can be sourced off a 90-94 Infiniti g20
i can see why in alaska u wouldnt need a/c... but for 40lbs, i think its worth keeping. the car makes plenty of power and torque, however im not tracking the car like u possibly. it's my daily driver and im getting old enough to the point where a stripped out all out racer is no longer cool nor livable.
i would rather move the battery and replace it with a lightweight drycell to the trunk and the washer bottle to the trunk. Plus it would help out the sh*tty weight distribution and make space for a fmic, in my opinion. 12lbs for the bottle and motor, 40lbs for the battery. plus the battery sits up high and right at the front, and the washerbottle sits way up front.
i've compressed all my part numbers into a single post, which would be post number 2. lets try to keep them in one spot, or create a faq for this gti-r forum
Not that i think you would BS me . I guess i should have asked if you have actually used the p10 windshield in the RNN14. I understand you said it will fit but i need to be clear before i drop $ on something based upon here say or actual experience.
Many give advice and input based on just what they hear and not what they "know" from hands /1st hand experience. Appreciate help.
now is the for the 5 bolt gasket or the 3 bolt exhaust? *** i need the ring gasket elbow to downpipe. The exhaust shops dont seem to have the right configuration.
