Old 05-09-2007, 02:13 PM   #1 (permalink)
MSD *** 4 on GTiR
I fitting a MSD *** 4 on GTiR
but i not sure what coil that suitable to use
the only option i found from MSD website is
Blaster *** Racing Coil
http://www.msdignition.com/coil_blaster_2_8230.htm
Blaster SS Coil
http://www.msdignition.com/coil_blaster_6_8207.htm
anyone familiar with this MSD related stuff ?
need some guide
emailed MSD but no reply from them
and what is recommended plug wire ?
Thank you
Arrhh
cmng is offline   Reply With Quote
Old 05-09-2007, 02:28 PM   #2 (permalink)
SE-R Turbo Slut
Trader Rating: 29 (100%)
You already have the ***? Not sure how MSD affects DETs but there are known drivibiltiy issues which MSD has admitted OBD1 igniton circuitry isnt happy with .Msd on the lower end of rpm range cause stumbling issues. . Seems that the Crane is better suited for 91-94 and msd if fine 95+ .
Larry Low
LAMO IMPORTS
k6 GSXR 750
01 Ducati 996
1999 sentra se-l
1992 Pulsar Gti-r
Low612 is offline   Reply With Quote
Old 05-09-2007, 02:36 PM   #3 (permalink)
i already have the *** 4
not running OEM ECU anymore..
Running AEM ECU
so i dont think the OBD1 related issue anymore
Thank for the feedback
Old 05-09-2007, 02:41 PM   #4 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
Nope, you are set with the MSD and the AEM box. I have the Digital6 MSD box with blaster SS coil going in my NX. I had it setup in the sentra and it worked fine. Not sure why GTi-R would be any different, I think you are fine.
Brent
coach is online now   Reply With Quote
Old 05-10-2007, 02:46 AM   #5 (permalink)
Coach
But that is Digital 6
i running *** 4 and planning to run distributor less on the car
i know the 4 unit of *** Racing Coil will work.. not sure the
not sure 4 unit of blaster SS coil will work or not
Old 05-16-2007, 06:05 PM   #6 (permalink)
Originally Posted by cmng View Post
Coach
can u go distributer less with the msd digital 6?
nismoboy is offline   Reply With Quote
Old 05-18-2007, 05:59 PM   #7 (permalink)
You want how many lengths
I ran the GEN II Crane HI-6S amp matched with a PS-91 Fireball coil on my highport DE and my motor ran like it JUST rolled off the showroom floor. I plan on running the same ignition set-up with my GTi-R motor build - see how it turns out; very pleased with Crane's products.
LONG LIVE THE SR20!!
DRIFTING THE ABSTRACT!!
I'm also an authorized dealer for MimoUSA.
If anyone needs parts new, contact me.
nxgripspec is offline   Reply With Quote
Old 05-22-2007, 09:23 AM   #8 (permalink)
Any one can help ?
Can 4 unit of Blaster SS work on MSD *** 4 ?
Thank you
Old 05-23-2007, 06:48 AM   #9 (permalink)
Ok.. MSD tech support replied and it work
now the next headache
Plug wire and location to mount the Coil !
Old 05-23-2007, 11:58 AM   #10 (permalink)
SE-R Turbo Slut
Make a rectangular plate made of abs plastic or alluminium mount the 4 coils to it and place where battery tray is. I guess something like this: http://www.aa1car.com/library/2004/us20406.htm
Old 05-23-2007, 12:49 PM   #11 (permalink)
yes..
that what i thinking but where to put it only
since the location determine the cable length
Thank for the idea
