well i finished putting everything back together and in the car after major disasemblemnet*(not sure thats the word or if its even spelled right) but anyways
i have still the stock inj. and stock maf, but i have apex-i power fc with commander, i read up on it and i needed to give the ecu harness more power (+) so it will actually turn on the new ecu, but it now starts my car and immediately shuts it off, the commander tells me that the ecc(power,eccs), ntr(neutral gear),ign(ignition) have problems
now the power should be normal, and of course the car is in neutral, but the ignition is the inj., fuel pump and distributor. is this correct?
now i know the inj. are firing and the fuel pump turns on and stays on,
so my guess its the distributor?
