Old 06-11-2007, 05:44 PM   #1 (permalink)
Quick measurement help
Can someone take a quick measurement for me? I need to know the distance from the front axles to the shift lever. A rough estimate would be nice, but the more accurace the better.
Even better yet, has anyone ever seen a chassic diagram for this car? They typically use them in body shops to straighten frames.
jeffg is offline   Reply With Quote
Old 06-11-2007, 10:19 PM   #2 (permalink)
i got AWD so let it snow!
could you be a little moe specific? what part of the front axles? and by shift kever you mean the point under the stick shift itself? i have a set of original factory sevice manuals so i should be able to get this info for you.
what are you up to, if you dont mind me asking?
akchang is offline   Reply With Quote
Old 06-12-2007, 04:01 AM   #3 (permalink)
The measurement I needed was from the centerline of the front axles to the actual gear change lever inside the car. ideally this measurment would be taken down the center of the car.
I am measure this to determine driver's seating postion relative to the front axles. The gear shift is a common point in most cars and allows for easy comparison between models.
