I am on the look out to get some cams, what GTi-R cams do you guys use?
I was looking at the Tomei ones with 260 duration and 12mm lift, but Tomei only make a valve spring which is rated to 11.8mm.
I was looking at the Brian Crower website and it states that you can use the s13 cams in a iR, i thought they were different?
Has anyone had any experiences with JUN cams, i was thinking that the lift isnt high enough? 264 degree with 10.8mm lift.
I am going to be using a GT2871 turbo if that helps. . .
