Old 07-21-2008, 07:39 AM   #1 (permalink)
Smoke-son
Need help with Gti-r Wiring harness????
Need help asap....I bought a pulsar gti-r front clip and installed it on my 97'' 200sx se. Converted it to stick, the hole nine. I'm using the o.g harness from the gtir and ecu the rest is usdm sr20 parts. But I ran into problems the 2nd piece of the harness that wires up the the dash. Does anyone have the colors or diagram of the jdm harness, then to the B14 harness?Thanks.....
smoke153 is offline   Reply With Quote
Old 07-21-2008, 08:39 AM   #2 (permalink)
gtir raw power
theo's Avatar
the gtir is a obd1, your 97 is a obd2. get a b14 se-r harness and get a b14 se-r computer prog. for a pulsar setup or if you want to use the gtir computer , get a obd1 to obd2 adapter or you can figure out the wiring, http://www.vizi0n.com/pulsar/service_manual/ do you have any parts leftover from your clip?
theo is offline   Reply With Quote
