Originally Posted by CanadianR
excellent. What have you done for the need of the z32 air flow meter?
Did you need to retune any of the ecu or ?
Good looking engine bay. Where did you get your oil cooler and relocation kit, and does it come with a thermostat built in?
Looks pretty good under there.
For the MAF:
- rewire the connector (make sure you get the plug with your N62 MAF)
- retune the ECU so it reads/interprets the voltage output correctly (daughterboard installed in your OE ecu + program the 2 eeproms)
I can hook you up with an awesome guy in Montreal for this (you ship your ECU, he does the work and you get it back in a few weeks...)
Oil cooler comes from
http://www.batinc.net/
They are the MOCAL distributor in America. Talk to Peter (peter@batinc.net)
- not cheap but quality bits (lines, 10-row cooler and thermostat were about 500$ total)
- get the MOCAL oil relocation, not the cheap one (45$ instead of 25$) like I did. Other then that, Peter even shipped me a second gasket to resolve a leak issue.... great service.
- yes I got the thermostat built in the sandwich plate (always a bit opened, but fully opens around 85 degres C )
Any other questions I'd be glad to help, as always
Cheers,
--McDave
