Lifter Shims - SR20 Forum
Old 02-05-2010, 11:53 AM   #1 (permalink)
Lifter Shims
Hey I did add to an old post regarding this but I figured posting in here may be more appropriate.
I'm trying to source lifter shims for my gtir.. I've measured em up and the like now I need to find where to buy them, my Nissan dealer is quite confused. is the term "lifter Shim" correct?
Also it seems to me that there prety generic can i just order em from an autozone or oreilly?
Any input on sourcing these parts would be awesome!
thnx
1990 pulsar GTiR RB. reving to 4k at 60MPH in 5th gear
I <3 85 to 95 JDM!
ZED_not_zee is offline   Reply With Quote
Old 02-09-2010, 05:17 PM   #2 (permalink)
One is called shim and the other is rocker arm guide.There are 81 different thicknesses.from 0.0951in to 0.1378in increment 0.0010. They are not cheap either!!! Cheap solution is, use the feeler gauge and cut from it the correct thickness and put between valve top and shim/ rocker arm guide. It seems to work and in all fairness they have no place to go from there.
astarozna is offline   Reply With Quote
Old 02-24-2010, 06:53 AM   #3 (permalink)
We have a place here in australia that make them and are a hell lot cheaper than nissan..
Also have a look here numbers 23 and 21 is what you need..
http://nissan4u.com/parts/sunny/er_n...llustration_2/
YB35HI is offline   Reply With Quote
Old 03-08-2010, 12:17 PM   #4 (permalink)
Excelent responses thanks... I wasn't sure of the proper part name I was staring at Nissan 4 u for a while and couldn't be sure of the diagram.
hr-mm feeler gauge sets are cheap I might try that... why not! I can't see them moving around either...
Old 03-16-2010, 05:57 PM   #5 (permalink)
CDN GTiR
follow pulsarbobby's guide on gtiroc!
CanadianR is offline   Reply With Quote
Old 03-18-2010, 05:05 AM   #6 (permalink)
Here is the people in australia's website..
http://www.precisionshims.com.au/
Old 03-18-2010, 10:51 AM   #7 (permalink)
Feedback Score: 13 reviews
hey guys
My shims are WAY off also, some of them measure .018 inch in gap. i dont like the idea of putting cut peices of guage between my shim and valve but if i havent kicked a rocker with them being this loose then odds are i probebly and less likely to loose one when they are tight correct?
anyway if anyone has a f-up head and some used shims/guides kickin around id surely buy them
dxpxe is offline   Reply With Quote
Old 03-24-2010, 01:15 PM   #8 (permalink)
Yes I think I might.. Ive contacted Precision shim Australia I'll see what they say..
Old 03-24-2010, 01:20 PM   #9 (permalink)
gtir raw power
Feedback Score: 16 reviews
it definately works, my friend did it on his 2.2 gtir motor, the head is extremely quiet
theo is offline   Reply With Quote
Old 04-14-2010, 05:06 AM   #10 (permalink)
CDN GTiR
He didn't happen to take any pictures, did he? I want to do the same as he did, but am a bit nervous without pictures!
