Realtime ECU Emulator Command Protocol - SR20 Forum
Old 05-21-2007, 01:01 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
This is for you guys writing your own software. Its actually pretty simple to work with, there are really only three commands needed (version, read block, write block). Got questions just post them here.
The screen shots are of a cheesy little Labview program I wrote called 'Serial Talker'. Its basically a simple terminal program that lets you flip back and forth between writing hex or ascii commands, and shows responses in both hex and ascii. Very useful for walking through serial protocols. If there is interest I'll put the source on the web.
Not mentioned in the manual is that the connection speed is 115200 (oops, forgot to put that in there!).
http://www.calumsult.com/calumsu/Pro...mand%20Set.pdf
