realtime for s14 - SR20 Forum
Old 05-24-2007, 04:46 AM   #1 (permalink)
SR's are a fad
realtime for s14
hi, im interested in the realtime setup for a '95 s14 with ka24de. i couldnt find a rundown on the features, maybe you could point me in the direction? also is this a daughterboard type setup, or a completely new ecu?
rage is offline   Reply With Quote
Old 05-24-2007, 05:36 PM   #2 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Its a daughterboard setup, but not anything like a traditional ROM board.
This is a cut and paste from a different thread:
"-You need a core to send me. If your planning on using the Enthalpy as a base, you need an identical core and to also send me the Enthalpy ecu if you haven't already extracted the bin
-The Realtime includes just the hardware. I can also supply base programs depending on your setup, but I've got waaaay more experience with SR stuff than KA. For software, on the Consult side you can use any existing Consult software (I like Nissan DataScan $30 for map tracing, and CalumSult for datalogging). For Rom editing, again you can use any software, but TunerProRT really is the best to take advantage of the 'Realtime' features.
Here's a much longer description (e-mail or post if you've got more questions):
"The Realtime ECU uses a single USB connection that adds two new com ports to your pc when you connect. One is a standard consult connection (works with all existing consult software), and the other is the for the eumlation stuff. There are no ROM chips on the board, and you don't add anything. The emulation side supports a subset of the Romulator protocol, and EmUtility and TunerProRT both work great with it. The emulator protocol is also open if you want to write your own custom software (the command set is pretty straightforward). I use TunerProRT for realtime tuning, Nissan DataScan for map tracing and general consult functions, and good old CalumSult for datalogging.
All changes can be done 'realtime', while the engine is running. Makes tuning k-values and such pretty quick. You can also upload your bin to the ecu without the ecu being installed in the car, it will power off the USB port.
The consult circuit is also 'smart': if you have a consult device (techtom, n-probe, real CONSULT unit, etc) plugged in the daughterboard automatically shuts its own consult circuit off.
And thats all it does. No extra features, no bells and whistles, no firmware updates, just pure tuning.
The B13/S13 is $350 and the B14/S14 is $375. Both prices include install and return shipping (you ship me a core first of course). I also do demos at various shops (USA only). " "
If you've got more questions just post or give me a call (my cell is on the order form).
http://www.calumsult.com/calumsu/order%20form.htm
Old 05-26-2007, 12:13 PM   #3 (permalink)
hey im interested in a realtime setup for my b14 i have msd 72# injectors z32 maf turbonetics t3t4 60-1 3 inch exhaust if u can get back to me asap i would appreciate it thanks
200sxT95 is offline   Reply With Quote
Old 05-28-2007, 02:51 PM   #4 (permalink)
ClamSlut
Calum's Avatar
Just shoot me an e-mail or give me a call sometime.
