My car SHOULD be back together and running tommorrow. If you didn't know I had an incident where my timing chain broke, which bent 5 valves. Got most of it back together and will be finishing it up in the morning. I'm planning on going to the track friday night for some NA runs and figured your tuned NA program would be better than stock. Can you send me the program? Good chance I'll need some help putting it on the ecu too lol. I read the how to and downloaded the programs already.
Thanks for your time!!!!
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
