Tuning W/ECU out of Car - SR20 Forum
Old 07-09-2007, 11:37 PM   #1 (permalink)
The DET is in!
Feedback Score: 17 reviews
I want to put a different program on the ECU while it is out of the car. Is this possible? I have it all hooked up but when I click Upload Current Bin to Emulator it says: "Failure: Bin is larger then emulation ram." Then it says I need to use bank 8 or something. What is up?
TPRT does detect the Romulator...
W11 Avenir
GTi-R T28 Setup
Greddy Type S BOV
FMIC
Calum Realtime
Z32 MAF
Subaru 520cc Injectors
O2 Induction Style Manifold
Autometer: Water, Oil, Boost
3.5" Front Bumper Side Exit Exhaust
Progress Coilovers
Walbro 255lph
Nismo AFPR
ACT Xtreme Clutch
Prothane Motor Mount Inserts
RedDragun is offline   Reply With Quote
Old 07-10-2007, 07:58 AM   #2 (permalink)
Retired for now...
Feedback Score: 21 reviews
b13 or b14?? maybe loading wrong type??? 32 obd1 and 64 obd2
were a community not a ad site.
U12BBDreamer06 is offline   Reply With Quote
Old 07-10-2007, 09:09 AM   #3 (permalink)
Done.
Feedback Score: 27 reviews
I had the same problem. I found out that TPRT was not trying to see the ram as a larger size than it actually is. It's supposed to be 64K.
SR20DEEP MD
05 Armada - Tow Truck
04 Subaru WRX 'goon
Cliff está en línea   Reply With Quote
Old 07-10-2007, 09:57 AM   #4 (permalink)
The DET is in!
It's a B13. Where do I change it to 32k?
Old 07-10-2007, 10:24 AM   #5 (permalink)
Done.
I have no clue. I gave up on TPRT and just uninstalled, rebooted, and reinstalled.
Then when you pull the first bin, it'll ask you what size it is, and I just told it 64K for my B14. Obviously you'd tell it 32K for your B13.
Old 07-10-2007, 10:49 AM   #6 (permalink)
The DET is in!
I tried reinstalling TPRT and it still doesn't work... I was able to send a bin to the ECU once, but now whenever I try to verify the program crashes.
Old 07-10-2007, 11:22 AM   #7 (permalink)
The DET is in!
I know what the problem is (I think). The B13RT.xdf file is actually the B14 file. If you look at the header for it, it says so. So where is the real B13 XDF?
Old 07-10-2007, 02:14 PM   #8 (permalink)
The DET is in!
Bump, can someone please send me there working B13 XDF to lazerman at cox dot net!
Old 07-10-2007, 03:12 PM   #9 (permalink)
Done.
http://www.calumsult.com/calumsu/Pro...roRT/B13RT.xdf
Is that the one you used?
Old 07-10-2007, 04:29 PM   #10 (permalink)
The DET is in!
Yep. Click the link. It will take you to a text file and you can even read it yourself. It says it's for a B14.
Old 07-11-2007, 10:52 AM   #11 (permalink)
The DET is in!
Bump! I'm still having the same problem even with a different XDF (still says it is for a B14 in the header file which is weird).
Old 07-11-2007, 01:05 PM   #12 (permalink)
Done.
That is wierd. I'm sure someone around here has the B13 XDF file
Old 07-12-2007, 02:46 PM   #13 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Its the right one. Ignore the B14 bit, I forgot to change that.
Follow the quick start guide.
Old 07-12-2007, 04:05 PM   #14 (permalink)
The DET is in!
Thanks, I'll try it all again.
Did you get the program sent Calum?
I'm gonna call you tonight to bug you until you do!
Old 07-13-2007, 07:37 PM   #15 (permalink)
The DET is in!
Ok my problem is the drivers. Is there anyway I can uninstall the FTDI drivers and start all over fresh (I plugged the ecu in before installing the FTDI drivers). I think this will solve my problems...
Old 08-06-2007, 09:34 PM   #16 (permalink)
did you ever sort this out? I am haveing the same problem.
Fastspec2 is offline   Reply With Quote
Old 08-06-2007, 10:10 PM   #17 (permalink)
The DET is in!
Well now I just hit the emulate button then hit update on whatever I have open (like k value or something). I still can't get the upload/download full bins to work, I had to use EmUtility.
Old 09-10-2007, 03:30 AM   #18 (permalink)
neo in NY
Feedback Score: 4 reviews
has anyone used nissan datascan with their ecu? i have a b13 ecu (93 nx2000) i'm installing a sr20ve neo vvl motor. i'm interested in calum's realtime ecu upgrade. In terms of software, would nissan data scan be a good tool to use?
ronnx is offline   Reply With Quote
